09-05-2018 11:31 AM - edited 03-08-2019 04:05 PM
So I do the following on my lab 4500 switches and see the following when showing virtual link and switch virtual commands are issued. Can anyone help point me to fix the errors?
sh switch virtual link:
Executing the command on VSS member switch role = VSS Active, id = 1
VSL Status : DOWN
VSL Uptime : -
VSL Control Link : -
VSL Encryption : Configured Mode - Off, Operational Mode - Off
Cannot execute command on peer supervisor because it is not in SSO Standby state
sh switch virtual
Switch mode : Virtual Switch
Virtual switch domain number : 1
Local switch number : 1
Local switch operational role: Virtual Switch Active
09-05-2018 01:35 PM
can you give us steps how you configured and post both the switch configuration.
how are these ports connected. do you see ports are up ?
=====️ Preenayamo Vasudevam ️=====
09-06-2018 06:17 PM
04-20-2020 08:48 PM
i am facing the same issue here is my configuration , both switches are in active role
switch1#sh switch virtual
Virtual switch domain number : 100
C
Press RETURN to get started!
switch1>
switch1>en
switch1#swit
switch1#switch co
switch1#switch convert st
switch1#switch convert sta
switch1#switch convert m
switch1#switch convert mode st
switch1#switch convert mode stand-alone
This command will convert all interface names
to naming convention "interface-type slot/port",
save the running config to startup-config and
reload the switch.
VSL, if up, will go down during the conversion and
may cause dual-active condition for a brief period.
Do you want to proceed? [yes/no]: y
Converting interface names
Moving an interface from vsl to non-vsl, while system is running, might cause loop in the network. So, interface is being put to admin down state. Please execute `no shutdown` on the interface to remove admin down state
Building configuration...
Compressed configuration from 3430 bytes to 1862 bytes[OK]
Rebooting the switch
*Apr 20 17:56:09.230: %RF-5-RF_RELOAD: Shelf reload. Reason: Mode conversion
*Apr 20 17:56:09.297: %SYS-5-RELOAD: Reload requested Reload Reason: Mode conversion.
*Apr 20 17:56:09.539: %IOSXE-3-PLATFORM: 1 process sysmgr: Reset/Reload requested by [console].
<Mon Apr 20 17:56:09 2020> Message from sysmgr: Reason Code:[3] Reset Reason:Reset/Reload requested by [console]. [Reload command]
umount: /proc/fs/nfsd: not mounted
/tmp/sw/mount/cat4500e-base.SPA.03.10.03.E.pkg:m
Please stand by while rebooting the system...
[58610.555536] Restarting system.
Rommon (G) Signature verification PASSED
Rommon (P) Signature verification PASSED
FPGA (P) Signature verification PASSED
* Welcome to Rom Monitor for WS-C4500X-16 System. *
* Copyright (c) 2008-2019 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor (P) Version 15.0(1r)SG(16)
CPU Rev: 2.2, Board Rev: 9, Board Type: 108
CPLD Mobat Rev: 3.0x74b8.0x01db
Chassis: WS-C4500X-16
MAC Address : f0-7f-06-99-98-3f
IP Address : 172.16.222.62
Netmask : 255.255.255.248
Gateway : 172.16.22.57
TftpServer : Not set.
Non-Redundant system or peer not running IOS
System Uplinks & Linecards have been reset!!
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
Management Ethernet Link Up: 1Gb Full Duplex
******** The system will autoboot now ********
config-register = 0x2102
Autobooting using BOOT variable specified file.....
Current BOOT file is --- bootflash:cat4500e-universalk9.SPA.03.10.03.E.152-6.E3.bin
Loading image !!!!!!!!!!!!!!!!!!!!!!!!!
Checking digital signature....
[bootflash:/cat4500e-universalk9.SPA.03.10.03.E.152-6.E3.bin]
Digitally Signed Release Software with key version A
Rommon reg: 0x00084F80
Reset2Reg: 0x00004F00
Image load status: 0x00000003
Radtrooper 064 controller 0x047F44FC..0x04990096 Size:0x00661EDC
Program Done!
[ 0.058438] pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
[ 0.148672] pci 0001:04:00.0: ignoring class b20 (doesn't match header type 01)
[ 0.241271] pci 0002:0c:00.0: ignoring class b20 (doesn't match header type 01)
Starting System Services
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=4,mode=600,ptmxmode=000 0 0
diagsk10-post version 5.1.4.1
prod: WS-C4500X-16 part: 73-14786-05 serial: JAE183703WN
Power-on-self-test for Module 1: WS-C4500X-16
CPU Subsystem Tests ...
seeprom: Pass
Traffic: L3 Loopback ...
Test Results: Pass
Traffic: L2 Loopback ...
Test Results: Pass
post done(56 secs)
Exiting to ios...
Continuing with IOS boot..
Apr 20 17:59:49 %IOSXE-3-PLATFORM: process kernel: [ 86.841378] mpc85xx_pci_err_probe: Unable to requiest irq 0 for MPC85xx PCI err
Apr 20 17:59:49 %IOSXE-3-PLATFORM: process kernel: [ 86.851679] mpc85xx_pcie_err_probe: Unable to requiest irq 0 for MPC85xx PCIe err
Loading gsbu64atomic as gdb64atomic
Loading pds_kc_flowcntl for kstack
loading kstack module
Loading container module
Failed to bring interface "eth1" up
Using 1 for MTS slot
Platform Manager: starting in standalone mode (active)
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.10.03.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Mon 15-Jul-19 08:51 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C4500X-16 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
Processor board ID JAE183703WN
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from Reload
1 Virtual Ethernet interface
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
redundancy
% Invalid input detected at '^' marker.
mode sso
*Apr 20 18:00:25.578: %BUFCAP-6-EPC_RF_INFRA: EPC rf infra registration is SUCCESS
*Apr 20 18:00:31.016: %C4K_IOSSYS-6-IMAGELEVEL: Supervisor booting in image level 'entservices'
*Apr 20 18:00:37.309: %C4K_SWITCHINGENGINEMAN-6-BFDINVALIDPACKETACLAPPLIED: Control plane protection against invalid BFD packets is applied
*Apr 20 18:01:14.873: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Apr 20 18:01:16.861: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4500X-16 S/N: JAE183703WN Hw
switch1>
switch1>
switch1>
switch1>
switch1>: 1.1) is online
*Apr 20 18:01:22.414: %SYS-5-CONFIG_I: Configured from memory by consoleSystem has been configured
*Apr 20 18:01:22.731: %SYS-5-RESTART: System restarted --
*Apr 20 18:01:23.720: %HA_EM-6-LOG: cpu_stats_cor1: ------HIGH CPU DETECTED----, CPU: 89 %
*Apr 20 18:01:24.866: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=1: Transceiver has been inserted
*Apr 20 18:01:26.863: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=2: Transceiver has been inserted
*Apr 20 18:01:27.804: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Apr 20 18:01:28.863: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=3: Transceiver has been inserted
switch1>
switch1>en
switch1#sh sw
Switch Mode : Standalone
Not in Virtual Switch mode due to:
Domain ID is not configured
switch1#sh runn
switch1#sh running-config
Current configuration : 3497 bytes
! Last configuration change at 18:01:32 UTC Mon Apr 20 2020
version 15.2
no service pad
service compress-config
hostname switch1
boot-start-marker
boot system bootflash:cat4500e-universalk9.SPA.03.10.03.E.152-6.E3.bin
boot-end-marker
vrf definition mgmtVrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
vtp domain bankavers
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode rapid-pvst
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
ip address 50.50.50.1 255.255.255.0
interface FastEthernet1
vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface TenGigabitEthernet1/3
switchport mode trunk
shutdown
interface TenGigabitEthernet1/4
shutdown
interface TenGigabitEthernet1/5
shutdown
interface TenGigabitEthernet1/6
shutdown
interface TenGigabitEthernet1/7
shutdown
interface TenGigabitEthernet1/8
shutdown
interface TenGigabitEthernet1/9
shutdown
interface TenGigabitEthernet1/10
shutdown
interface TenGigabitEthernet1/11
shutdown
interface TenGigabitEthernet1/12
shutdown
interface TenGigabitEthernet1/13
shutdown
interface TenGigabitEthernet1/14
shutdown
interface TenGigabitEthernet1/15
shutdown
interface TenGigabitEthernet1/16
shutdown
interface Vlan1
no ip address
interface Vlan100
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
switch1#sh ip in
switch1#sh ip interface br
switch1#sh ip interface brief
FastEthernet1 unassigned YES unset up up
TenGigabitEthernet1/1 unassigned YES unset up up
TenGigabitEthernet1/2 unassigned YES unset up up
TenGigabitEthernet1/3 unassigned YES unset administratively down down
TenGigabitEthernet1/4 unassigned YES unset administratively down down
TenGigabitEthernet1/5 unassigned YES unset administratively down down
TenGigabitEthernet1/6 unassigned YES unset administratively down down
TenGigabitEthernet1/7 unassigned YES unset administratively down down
TenGigabitEthernet1/8 unassigned YES unset administratively down down
TenGigabitEthernet1/9 unassigned YES unset administratively down down
TenGigabitEthernet1/10 unassigned YES unset administratively down down
TenGigabitEthernet1/11 unassigned YES unset administratively down down
TenGigabitEthernet1/12 unassigned YES unset administratively down down
TenGigabitEthernet1/13 unassigned YES unset administratively down down
TenGigabitEthernet1/14 unassigned YES unset administratively down down
TenGigabitEthernet1/15 unassigned YES unset administratively down down
TenGigabitEthernet1/16 unassigned YES unset administratively down down
Loopback0 50.50.50.1 YES NVRAM up up
Vlan1 unassigned YES unset up up
Vlan100 unassigned YES unset down down
switch1#sw
switch1#switch vi
switch1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
switch1(config)#sw
switch1(config)#switch vi
switch1(config)#switch virtual do
switch1(config)#switch virtual domain 100
Domain ID 100 config will take effect only
after the exec command 'switch convert mode virtual' is issued
switch1(config-vs-domain)#sw
switch1(config-vs-domain)#switch 1
switch1(config-vs-domain)#exit
switch1(config)#int
switch1(config)#interface po
switch1(config)#interface port-channel 10
switch1(config-if)#sw
switch1(config-if)#switch vi
switch1(config-if)#switch virtual li
switch1(config-if)#switch virtual link 1
WARNING:Port channel number for VSL on both chassis should not be same
Interface Po10 is a Layer 3 interface.
Convert it to a Layer 2 switchport before
configuring it as a VSL Port-channel.
switch1(config-if)#no shu
switch1(config-if)#no shutdown
switch1(config-if)#exit
switch1(config)#interface te
switch1(config)#interface rang
switch1(config)#interface range te
switch1(config)#interface range tenGigabitEthernet 1/1/1-2
switch1(config)#interface range tenGigabitEthernet 1/1-2
switch1(config-if-range)#chan
switch1(config-if-range)#channel-g
switch1(config-if-range)#channel-group 10
switch1(config-if-range)#channel-group 10 mo
switch1(config-if-range)#channel-group 10 mode on
Command rejected (Port-channel10, Te1/1): Either port is L2 and port-channel is L3, or vice-versa
% Range command terminated because it failed on TenGigabitEthernet1/1
switch1(config-if-range)#$rt is L2 and port-channel is L3, or vice-versa
Command rejected (Port-channel10, Te1/1): Either port is L2 and port-channel is ^L3, or vice-versa
switch1(config-if-range)#exit
switch1(config-if)#switchpo
switch1(config-if)#switchport
switch1(config-if)#do wr
Compressed configuration from 3591 bytes to 1959 bytes[OK]
switch1(config-if)#interface range tenGigabitEthernet 1/1-2
*Apr 20 18:11:55.404: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1 joined port-channel Port-channel10
*Apr 20 18:11:55.413: %EC-5-BUNDLE: Interface TenGigabitEthernet1/2 joined port-channel Port-channel10
switch1(config-if-range)#no shut
switch1(config-if-range)#no shutdown
switch1(config-if-range)#do wr
Compressed configuration from 3643 bytes to 1987 bytes[OK]
*Apr 20 18:13:10.458: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po10, putting Te1/1 in err-disable state
*Apr 20 18:13:10.460: %EC-5-UNBUNDLE: Interface TenGigabitEthernet1/1 left the port-channel Port-channel10
*Apr 20 18:13:10.460: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po10, putting Te1/2 in err-disable state
*Apr 20 18:13:10.475: %EC-5-UNBUNDLE: Interface TenGigabitEthernet1/2 left the port-channel Port-channel10
*Apr 20 18:13:10.476: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po10, putting Po10 in err-disable state
switch1(config-if-range)#do sh run
Current configuration : 3643 bytes
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
mac-address use-virtual
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
interface Port-channel10
switchport
no ip address
speed auto
duplex auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
--More--
*Apr 20 18:21:30.966: %SFF8472-5-THRESHOLD_VIOLATION: Te1/1: Tx power low alarm; Operating value: -40.0 dBm, Threshold value: -11.3 dBm.
*Apr 20 18:21:34.961: %SFF8472-5-THRESHOLD_VIOLATION: Te1/2: Tx power low alarm; Operating value: -40.0 dBm, Threshold value: interface Vlan1
switch1(config-if-range)#$ on Po10, putting Te1/1 in err-disable state
ERR_DISABLE: channel-misconfig (STP) error detected on Po10, putting Te1/1 in er ^r-disable state
switch1(config-if-range)#sh ip int
switch1(config-if-range)#do sh ip int br
TenGigabitEthernet1/1 unassigned YES unset down down
TenGigabitEthernet1/2 unassigned YES unset down down
Port-channel10 unassigned YES unset down down
Vlan1 unassigned YES unset down down
switch1(config)#no interface port-channel 10
switch1(config)#do wr
Compressed configuration from 3572 bytes to 1943 bytes[OK]
switch1(config)#do sh run
Current configuration : 3572 bytes
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
no ip address
speed auto
duplex auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
switch1(config)#interface tenGigabitEthernet 1/1
switch1(config)#interface tenGigabitEthernet 1/2
switch1(config)#do sh ip int br
switch1(config)#conf t
switch1(config)#int
switch1(config-if-range)#port
*Apr 20 18:32:43.663: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1 joined port-channel Port-channel10
*Apr 20 18:32:43.670: %EC-5-BUNDLE: Interface TenGigabitEthernet1/2 joined port-channel Port-channel10no shut
Port-channel10 unassigned YES unset up up
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
switchport
no ip address
speed auto
duplex auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
switch1(config)#exit
switch1#
*Apr 20 18:35:24.154: %SYS-5-CONFIG_I: Configured from console by console
switch1#sw
switch1#switch con
switch1#switch convert mode vi
switch1#switch convert mode virtual
******************* CAUTION ******************
* No VSL port is configured or all VSL ports *
* are put in shutdown state. *
* This may cause Dual-Active mode of VSS. *
to naming convention "interface-type switch-number/slot/port",
reload the switch.
Compressed configuration from 3698 bytes to 2007 bytes[OK]
*Apr 20 18:35:52.349: %EC-5-UNBUNDLE: Interface TenGigabitEthernet1/1 left the port-channel Port-channel10
*Apr 20 18:35:52.365: %EC-5-UNBUNDLE: Interface TenGigabitEthernet1/2 left the port-channel Port-channel10
Saving converted configuration to bootflash: ...
Destination filename [startup-config.converted_vs-20200420-183555]?
3698 bytes copied in 0.004 secs (924500 bytes/sec)
switch1#
*Apr 20 18:36:46.509: %RF-5-RF_RELOAD: Shelf reload. Reason: Mode conversion
*Apr 20 18:36:46.661: %C4K_IOSSYS-6-SYSTEMMANAGERRELOADCB: System Manager requested shelf reload (by "", reason "Mode conversion")
*Apr 20 18:36:46.696: %SYS-5-RELOAD: Reload requested Reload Reason: Mode conversion.
*Apr 20 18:36:47.161: %IOSXE-3-PLATFORM: 1 process sysmgr: Reset/Reload requested by [console].
<Mon Apr 20 18:36:47 2020> Message from sysmgr: Reason Code:[3] Reset Reason:Reset/Reload requested by [console]. [Reload command]
/etc/rc6.d/S01reboot: line 198: umount_cisco_filesystems: command not found
[ 2331.602529] Restarting system.
Program Done!
[ 0.091233] pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
[ 0.181468] pci 0001:04:00.0: ignoring class b20 (doesn't match header type 01)
[ 0.274079] pci 0002:0c:00.0: ignoring class b20 (doesn't match header type 01)
seeprom: Pass
Test Results: Pass
Test Results: Pass
post done(56 secs)
Exiting to ios...
Apr 20 18:40:20 %IOSXE-3-PLATFORM: process kernel: [ 86.289644] mpc85xx_pci_err_probe: Unable to requiest irq 0 for MPC85xx PCI err
Apr 20 18:40:20 %IOSXE-3-PLATFORM: process kernel: [ 86.304463] mpc85xx_pcie_err_probe: Unable to requiest irq 0 for MPC85xx PCIe err
Platform Manager: starting in VSS mode (chassis id 1, in-chassis active)
cisco Systems, Inc.
software.
****************** CAUTION *******************
Initializing as Virtual Switch ACTIVE processor
[email protected].
*Apr 20 18:40:46.639: %BUFCAP-6-EPC_RF_INFRA: EPC rf infra registration is SUCCESS
*Apr 20 18:40:52.064: %C4K_IOSSYS-6-IMAGELEVEL: Supervisor booting in image level 'entservices'
*Apr 20 18:43:34.482: %VSLP-5-RRP_PEER_TIMEOUT: VSLP peer timer expired without detecting peer. Resolving role as Active
*Apr 20 18:43:34.518: %C4K_SWITCHINGENGINEMAN-6-BFDINVALIDPACKETACLAPPLIED: Control plane protection against invalid BFD packets is applied
*Apr 20 18:44:04.518: %C4K_REDUNDANCY-6-INIT: Initializing as ACTIVE supervisor
*Apr 20 18:44:06.051: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Apr 20 18:44:08.045: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4500X-16 S/N: JAE183703WN Hw: 1.1) is online
*Apr 20 18:44:14.209: %SYS-5-CONFIG_I: Configured from memory by console
*Apr 20 18:44:14.330: %C4K_QOS_NOVA-5-VSL_MGMT_ACL_MODIFIED: Access-list VSL-MGMT modified in running configuration.System has been configured
*Apr 20 18:44:14.511: %SYS-5-RESTART: System restarted --
*Apr 20 18:44:15.064: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1/1 joined port-channel Port-channel10
*Apr 20 18:44:15.075: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1/2 joined port-channel Port-channel10
*Apr 20 18:44:19.595: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
switch1>
switch1>
switch1>
switch1>en
switch1#sh sw
switch1#$d on peer supervisor because it is not in SSO Standby state
Cannot execute command on peer supervisor because it is not in SSO Standby state ^
switch1#sh sw
switch1#sh switch virtual li
switch1#sh switch virtual link
VSL Status : DOWN
VSL Uptime : -
switch1#sh po
switch1#sh port
switch1#sh port-ch
switch1#sh port-cha
switch1#shchann
switch1#sh ch
switch1#shport
switch1#sh ?
aaa Show AAA values
access-expression List access expression
access-group Access group information
access-lists List access lists
adjacency Adjacent nodes
aliases Display alias commands
alignment Show alignment information
ancp ANCP information
application Application Routing
archive Archive functions
arp ARP table
audit Router Audit
authentication Shows Auth Manager stats, registrations or sessions
auto Show Automation Template
avc Application visibility and control
backup Backup status
banner Display banner information
beep Show BEEP information
bfd BFD protocol info
bgp BGP information
bootflash: display information about bootflash: file system
bootvar Boot and related environment variable
bridge Bridge Forwarding/Filtering Database [verbose]
buffers Buffer pool statistics
bulkstat Bulkstat show commands
caaa Subscriber Policy Entity Information
cable-diagnostics Show Cable Diagnostics Results
cache Shows Device-Sensor Cache Informations
calendar Display the hardware calendar
call-home Show command for call home
capability Capability Information
cat4000_flash: display information about cat4000_flash: file system
cca CCA information
cce Common Classification Engine (CCE)
cdp CDP information
cef CEF address family independent status
checkpoint Checkpoint Facility (CF) and halib
ciscoview CiscoView ADP details
cisp Shows CISP information
class-map Show CPL Class Map
clns CLNS network information
clock Display the system clock
cmi CMI commands
cns CNS agents
coap CoAP show commands
compress Show compression statistics
configuration Contents of Non-Volatile memory
controllers Interface controller status
cops COPS information
crashinfo: display information about crashinfo: file system
crypto Encryption module
cts Cisco Trusted Security information
dampening Display dampening information
data-corruption Show data errors
dcm Data Collection Manager Core Details
debugging State of each debugging option
derived-config Derived operating configuration
device Display device classifier information
device-sensor Shows Device Sensor Information
dhcp Dynamic Host Configuration Protocol status
diag Show diagnostic and eeprom information
diagnostic Show command for diagnostic
dnsix Shows Dnsix/DMDP information
domain IOSd domain information
dot1q-tunnel Display dot1q tunnel ports
dot1x Dot1x information
dtp DTP information
eap Shows EAP registration/session information
eigrp EIGRP show commands
em Event Manager Show
energywise EnergyWise show commands
environment environmental status display commands
epm EPM information
errdisable Error disable
etherchannel EtherChannel information
ethernet Ethernet parameters
event Embedded event related commands
event-manager Event manager information
exception Exception handling information
fabric Show commands for Secure Fabric Management Macros
fallback Display Fallback configuration
ffm Properties of a single Forwarding and Feature Manager
instance
fhrp FHRP information
file Show filesystem information
fips FIPS mode show commands
flow Flow information
flow-sampler Display the flow samplers configured
flowcontrol show flow control information
format Show format information
glbp GLBP information
history Display the session command history
hosts IP domain-name, lookup style, nameservers, and host
table
html HTML helper commands
id-manager ID pool manager
idb List of Interface Descriptor Blocks
identity Identity profiles and policies
idprom show IDPROMs for chassis and supervisor
if-mgr if-mgr information
ifnum IDB Interface Index (Number)
iif Interface ID Factory info
interfaces Interface status and configuration
inventory Show the physical inventory
iosd IOSd infrastructure
ip IP information
ipc Interprocess communications commands
ipv6 IPv6 information
isis IS-IS routing information
issu ISSU Information
key Key information
keystore Show keystore information
kinfo: display information about kinfo: file system
kron Kron Subsystem
l2 Layer 2
l2fib Layer 2 Forwarding Information Base
l2protocol-tunnel Display L2PT status and configurations
lacp Port channel information
layer2 L2 information
license Show license information
line TTY line information
link Show Link
lisp Locator/ID Separation Protocol
lldp LLDP information
location Display the system location
logging Show the contents of logging buffers
login Display Secure Login Configurations and State
mab MAB information
mac MAC configuration
macdb show MAC database
macro Show command macros
macsec Shows MACSEC information
management Display the management applications
mdf Show the names of configured EMM menus
mdns MDNS feature
mediatrace Mediatrace show commands
memory Memory statistics
mfib MFIB address family independent status
mgmt-infra management infrastructure
mka MACsec Key Agreement (MKA) display
mlrib Multi Layer RIB information
module show linecard module information
monitor Monitoring different system events
mtm MTM
mvpn Multicast VPN Information
mvr Show mvr global parameters
netconf Show NETCONF information
network-policy Network Policy profile information
nhrp Display NHRP related information
nmsp nmsp show commands
ntp Network time protocol
object-group List object groups
odb Opaque Database
odm-format Show the schema used for ODM input file
onboard no description
onep ONEP related commands
oscore core-os information
ospfv3 OSPFv3 information
package Show posix clients compatibility
pagp Port channel information
parameter-map Show parameter map of type
parser Display parser information
passwd Secure Password
pds Show PDS information
performance Media Monitor show commands
persistent Show persistent information
platform Platform elam commands
platform show platform debug state
pm Show Port Manager commands
pnp Display PNP information
policy-manager Policy Manager
policy-map Show Policy Map
port-security Show secure port information
power Switch Power
pppoe Point to Point Protocol over Ethernet
pre PRE show commands
privilege Show current privilege level
processes Active process statistics
profile Media services profile application
protocols Active network routing protocols
python All active python sessions
qos Display QoS Information
qos Quality of Service show commands
switch1#sh ip int br
Te1/1/1 unassigned YES unset up up
Te1/1/2 unassigned YES unset up up
Te1/1/3 unassigned YES unset administratively down down
Te1/1/4 unassigned YES unset administratively down down
Te1/1/5 unassigned YES unset administratively down down
Te1/1/6 unassigned YES unset administratively down down
Te1/1/7 unassigned YES unset administratively down down
Te1/1/8 unassigned YES unset administratively down down
Te1/1/9 unassigned YES unset administratively down down
Te1/1/10 unassigned YES unset administratively down down
Te1/1/11 unassigned YES unset administratively down down
Te1/1/12 unassigned YES unset administratively down down
Te1/1/13 unassigned YES unset administratively down down
Te1/1/14 unassigned YES unset administratively down down
Te1/1/15 unassigned YES unset administratively down down
Te1/1/16 unassigned YES unset administratively down down
switch1#sh in
switch1#sh int
switch1#sh interfaces po
switch1#sh interfaces port-channel 10
Port-channel10 is up, line protocol is up (connected)
Hardware is EtherChannel, address is f07f.0699.9800 (bia f07f.0699.9800)
MTU 1500 bytes, BW 20000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 10Gb/s, media type is N/A
input flow-control is on, output flow-control is unsupported
Members in this channel: Te1/1/1 Te1/1/2
Last input 00:11:23, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
133 packets input, 26590 bytes, 0 no buffer
Received 133 broadcasts (133 multicasts)
switch1#conf t
switch1(config)#in
MESSAGE:
You are configuring VSL on interface Po10.
There are member ports already attached to the port channel.
Remove all member ports before configuring as VSL Port-Channel.
Compressed configuration from 4015 bytes to 2190 bytes[OK]
switch1#s
*Apr 20 19:00:25.691: %SYS-5-CONFIG_I: Configured from console by consoleh sw
VSL Status : DOWN
VSL Uptime : -
switch1#sw
switch1#switch mo
switch1#switch co
Switch is already in virtual switch mode.
switch1#sh logg
switch1#sh logging
Syslog logging: enabled (0 messages dropped, 4 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 15 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 15 messages logged, xml disabled,
filtering disabled
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 18 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (32768 bytes):
switch1#
switch1#
switch1#
switch1#sh sw
switch1#sh run | in port-channel
switch1#sh run
Current configuration : 4015 bytes
! Last configuration change at 19:00:25 UTC Mon Apr 20 2020
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
switch mode virtual
mac access-list extended VSL-MGMT
permit any 0022.bdcd.d200 0000.0000.00ff
permit 0022.bdcd.d200 0000.0000.00ff any
redundancy
mode sso
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
switchport
no ip address
speed auto
duplex auto
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
shutdown
interface TenGigabitEthernet1/1/4
shutdown
interface TenGigabitEthernet1/1/5
shutdown
interface TenGigabitEthernet1/1/6
shutdown
interface TenGigabitEthernet1/1/7
shutdown
interface TenGigabitEthernet1/1/8
shutdown
interface TenGigabitEthernet1/1/9
shutdown
interface TenGigabitEthernet1/1/10
shutdown
interface TenGigabitEthernet1/1/11
shutdown
interface TenGigabitEthernet1/1/12
shutdown
interface TenGigabitEthernet1/1/13
shutdown
interface TenGigabitEthernet1/1/14
switch1#inter
switch1#conf t
switch1(config)#in
MESSAGE:
Compressed configuration from 4015 bytes to 2196 bytes[OK]
switch1(config-if)#do reload
Proceed with reload? [confirm]
*Apr 20 19:11:28.169: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload command.
*Apr 20 19:11:28.346: %IOSXE-3-PLATFORM: 1 process sysmgr: Reset/Reload requested by [console].
<Mon Apr 20 19:11:28 2020> Message from sysmgr: Reason Code:[3] Reset Reason:Reset/Reload requested by [console]. [Reload command]
[ 1990.515228] Restarting system.
Program Done!
[ 0.091230] pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
[ 0.181464] pci 0001:04:00.0: ignoring class b20 (doesn't match header type 01)
[ 0.274077] pci 0002:0c:00.0: ignoring class b20 (doesn't match header type 01)
seeprom: Pass
Test Results: Pass
Test Results: Pass
post done(56 secs)
Exiting to ios...
Apr 20 19:15:09 %IOSXE-3-PLATFORM: process kernel: [ 87.846901] mpc85xx_pci_err_probe: Unable to requiest irq 0 for MPC85xx PCI err
Apr 20 19:15:09 %IOSXE-3-PLATFORM: process kernel: [ 87.860464] mpc85xx_pcie_err_probe: Unable to requiest irq 0 for MPC85xx PCIe err
cisco Systems, Inc.
software.
[email protected].
*Apr 20 19:15:35.793: %BUFCAP-6-EPC_RF_INFRA: EPC rf infra registration is SUCCESS
*Apr 20 19:15:41.639: %C4K_IOSSYS-6-IMAGELEVEL: Supervisor booting in image level 'entservices'
*Apr 20 19:18:24.115: %VSLP-5-RRP_PEER_TIMEOUT: VSLP peer timer expired without detecting peer. Resolving role as Active
*Apr 20 19:18:24.135: %C4K_SWITCHINGENGINEMAN-6-BFDINVALIDPACKETACLAPPLIED: Control plane protection against invalid BFD packets is applied
*Apr 20 19:18:54.203: %C4K_REDUNDANCY-6-INIT: Initializing as ACTIVE supervisor
*Apr 20 19:18:55.732: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Apr 20 19:18:57.706: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-C4500X-16 S/N: JAE183703WN Hw: 1.1) is online
*Apr 20 19:19:03.804: %SYS-5-CONFIG_I: Configured from memory by consoleSystem has been configured
*Apr 20 19:19:04.082: %SYS-5-RESTART: System restarted --
*Apr 20 19:19:09.159: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Apr 20 19:19:21.708: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1/1 joined port-channel Port-channel10
*Apr 20 19:19:21.718: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1/2 joined port-channel Port-channel10
switch1>
switch1>
switch1>en
switch1#sh sw
switch1#sh sw
VSL Status : DOWN
VSL Uptime : -
switch1#interf
switch1#conf t
switch1(config-if-range)#swpo
switch1(config-if-range)#switc
switch1(config-if-range)#switchport mo
switch1(config-if-range)#switchport mode tr
switch1(config-if-range)#switchport mode trunk
*Apr 20 19:27:27.377: %EC-5-UNBUNDLE: Interface TenGigabitEthernet1/1/1 left the port-channel Port-channel10
*Apr 20 19:27:27.400: %EC-5-UNBUNDLE: Interface TenGigabitEthernet1/1/2 left the port-channel Port-channel10
*Apr 20 19:27:30.376: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1/1 joined port-channel Port-channel10
*Apr 20 19:27:30.849: %EC-5-BUNDLE: Interface TenGigabitEthernet1/1/2 joined port-channel Port-channel10
switch1#
*Apr 20 19:29:13.016: %SYS-5-CONFIG_I: Configured from console by consoleshow sw
switch1#show switch vir
switch1#show switch virtual
switch1#shop
switch1#show sw
switch1#show switch virtual li
switch1#show switch virtual link
VSL Status : DOWN
VSL Uptime : -
switch1#VSL Status : DOWN
switch1#sh sw
switch1#switch1#sh switch virtual
switch1#
switch1#Executing the command on VSS member switch role = VSS Active, id = 1
switch1#
switch1#
switch1#Switch mode : Virtual Switch
switch1#Virtual switch domain number : 100
switch1#Local switch number : 1
switch1#Local switch operational role: Virtual Switch Active
switch1#show sw
VSL Status : DOWN
VSL Uptime : -
show run#
switch mode virtual
C
switch1>
switch1>en
switch1#swit
switch1#switch co
reload the switch.
Program Done!
seeprom: Pass
Test Results: Pass
Test Results: Pass
post done(56 secs)
Exiting to ios...
cisco Systems, Inc.
software.
[email protected].
redundancy
mode sso
switch1>
switch1>
switch1>
switch1>
switch1>
switch1>en
switch1#sh sw
switch1#sh runn
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
no ip address
speed auto
duplex auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
interface Vlan1
no ip address
interface Vlan100
no ip address
no ip http server
switch1#sh ip in
switch1#sw
switch1#switch vi
switch1#conf t
switch1(config)#sw
switch1(config)#int
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
switchport
no ip address
speed auto
duplex auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
--More--
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
no ip address
speed auto
duplex auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
switch1(config)#int
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
switchport
no ip address
speed auto
duplex auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
switch1#
switch1#sw
switch1#switch con
reload the switch.
switch1#
Program Done!
seeprom: Pass
Test Results: Pass
Test Results: Pass
post done(56 secs)
Exiting to ios...
cisco Systems, Inc.
software.
[email protected].
switch1>
switch1>
switch1>
switch1>en
switch1#sh sw
switch1#sh sw
VSL Status : DOWN
VSL Uptime : -
switch1#sh po
switch1#sh port
switch1#sh port-ch
switch1#sh port-cha
switch1#shchann
switch1#sh ch
switch1#shport
switch1#sh ?
aaa Show AAA values
arp ARP table
audit Router Audit
bgp BGP information
cca CCA information
cdp CDP information
cmi CMI commands
cns CNS agents
dtp DTP information
epm EPM information
instance
table
ip IP information
key Key information
kron Kron Subsystem
l2 Layer 2
link Show Link
mab MAB information
mdns MDNS feature
mtm MTM
odb Opaque Database
power Switch Power
switch1#sh in
switch1#sh int
switch1#conf t
switch1(config)#in
MESSAGE:
switch1#s
VSL Status : DOWN
VSL Uptime : -
switch1#sw
switch1#switch mo
switch1#switch co
switch1#sh logg
switch1#sh logging
filtering disabled
filtering disabled
filtering disabled
switch1#
switch1#
switch1#
switch1#sh sw
switch1#sh run
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
switch mode virtual
redundancy
mode sso
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
switchport
no ip address
speed auto
duplex auto
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
switch1#inter
switch1#conf t
switch1(config)#in
MESSAGE:
Program Done!
seeprom: Pass
Test Results: Pass
Test Results: Pass
post done(56 secs)
Exiting to ios...
cisco Systems, Inc.
software.
[email protected].
switch1>
switch1>
switch1>en
switch1#sh sw
switch1#sh sw
VSL Status : DOWN
VSL Uptime : -
switch1#interf
switch1#conf t
switch1#
switch1#shop
switch1#show sw
VSL Status : DOWN
VSL Uptime : -
switch1#sh sw
switch1#
switch1#
switch1#
switch1#show sw
VSL Status : DOWN
VSL Uptime : -
switch1#sh run
Current configuration : 4084 bytes
! Last configuration change at 19:29:13 UTC Mon Apr 20 2020
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
switch mode virtual
switch1#witch virtual domain 100
switch1# switch mode virtual
switch1# mac-address use-virtual
switch1#sh run
version 15.2
no service pad
hostname switch1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
switch mode virtual
redundancy
mode sso
vlan 2,10
vlan 100
name TEST
vlan 1006,1008-2000
interface Loopback0
switchport
no ip address
speed auto
duplex auto
i--
07-27-2022 08:23 AM
You have probably solved this but there is an issue - you configure switch virtual link under the PO interface but it seems the command has gone. Now you need to take out the ports from bundle first - under interface configuration mode - and enter port-channel interface, issue the virtual link command and after that rejoin the physical interfaces into port-channel.
Then it should work.
04-21-2020 06:43 AM - edited 04-21-2020 06:46 AM
So, there is something wrong with your virtual switch configuration or cable, optic, etc.. as the status shows interfaces are down. The output should look like this:
VSL Status : UP
VSL Uptime : 1 year, 39 weeks, 18 hours, 24 minutes
VSL Control Link : Te1/2/7
Executing the command on VSS member switch role = VSS Standby, id = 2
VSL Status : UP
VSL Uptime : 1 year, 39 weeks, 18 hours, 9 minutes
VSL Control Link : Te2/2/7
This basically shows that the link is up and also shows what port in the Portchannel is forwarding traffic. (2/27)
So, compare this to your output below:
VSL Status : DOWN
VSL Uptime : -
