Replacement Catalyst 9407 supervisor
g3doubt
Frequent Visitor
Frequent Visitor
I have an issue with a sup C9400-SUP-1XL and I will replace the active one.
The device has two supervisor and i will force a switchover to replace the one that is on slot 3.
The sups are on install mode so my question is the following: Once I put the new supervisor, does it upgrade automatically like the sups of 6500? If not, which will be the correct procedure?
sh module
Chassis Type: C9407R
Mod Ports Card Type Model Serial No.
1 48 48-Port UPOE 10/100/1000 (RJ-45) C9400-LC-48U JAD25320C3Q
2 48 48-Port UPOE 10/100/1000 (RJ-45) C9400-LC-48U JAD25320CU6
3 11 Supervisor 1 XL Module C9400-SUP-1XL JAD253300TR
4 11 Supervisor 1 XL Module C9400-SUP-1XL JAD253300V2
5 48 48-Port UPOE 10/100/1000 (RJ-45) C9400-LC-48U JAD25320CQL
6 24 24-Port 10 Gigabit Ethernet (SFP+) C9400-LC-24XS JAE25280W9A
Mod MAC addresses Hw Fw Sw Status
1 A478.069F.DCF0 to A478.069F.DD1F 1.1 17.3.1r[FC2] 17.03.04 ok
2 A478.06AC.FF00 to A478.06AC.FF2F 1.1 17.3.1r[FC2] 17.03.04 ok
3 BCD2.95CB.D1EC to BCD2.95CB.D1F6 2.1 17.3.1r[FC2] 17.03.04 ok
4 BCD2.95CB.D1F6 to BCD2.95CB.D200 2.1 17.3.1r[FC2] 17.03.04 ok
5 A478.069F.DCC0 to A478.069F.DCEF 1.1 17.3.1r[FC2] 17.03.04 ok
6 4C5D.3CAB.BA98 to 4C5D.3CAB.BAAF 1.0 17.3.1r[FC2] 17.03.04 ok
Mod Redundancy Role Operating Mode Configured Mode Redundancy Status
3 Active sso sso Active
4 Standby sso sso Standby Hot
balaji.bandi
You need to upgrade to IOS XE inline with active (once you replace the card -  Follow below guide :
https://www.cisco.com/c/en/us/support/docs/interfaces-modules/catalyst-9600-series-supervisor-engine-1/216193-replace-a-supervisor-module-or-stack-mem.html
BB
balaji.bandi
BB
The link was usefull.
It took time but it worked
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/support/docs/interfaces-modules/catalyst-9600-series-supervisor-engine-1/216193-replace-a-supervisor-module-or-stack-mem.html#anc29
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
lagerplane
Level 3
Level 3
Yes, because you are already running the device in Install Mode. Beside that requirement, you also want to make sure the auto-upgrade feature is enabled, when you do SW# show run all | inc software auto-upgrade you want to see the line "software auto-upgrade enable" listed.
The steps for that procedure are on this link below.
Replace a Supervisor Module or Stack Member of Catalyst 9000 in HA
Replace a Redundant Supervisor of C9400 Standalone Chassis
https://www.cisco.com/c/en/us/support/docs/interfaces-modules/catalyst-9600-series-supervisor-engine-1/216193-replace-a-supervisor-module-or-stack-mem.html#anc15
