switchback command in nexus
suthomas1
Level 7
Level 7
Hello All,
In a nexus switch (running vdc's), will using "switch back" command in one of the vdc's cause any operational issues?
Thanks in advance.
makkarips
Community Member
Switchback is used to switch from non-admin VDC to Admin VDC..
In Nexus, you can shift only from Admin VDC to any other VDC, using switchto vdc "VDC name" command.
Use switchback command to switch back to Admin VDC.
There will not be any operational issues.
