06-23-2009 08:17 AM - edited 03-06-2019 06:24 AM
Is there a command where I can find out if the ports had any connectivity lately with devices attached to them?
I'm trying to determine, without walking around, if the data ports at the cubicles are even in used.
06-23-2009 08:21 AM
show interfaces counters
Port InOctets InUcastPkts InMcastPkts InBcastPkts
Fa0/1 4172514 34681 0 6320
Fa0/2 62739 572 0 108
Fa0/3 0 0 0 0
Fa0/4 0 0 0 0
Fa0/5 544 0 0 8
Fa0/6 0 0 0 0
Fa0/7 0 0 0 0
Fa0/8 0 0 0 0
06-23-2009 09:43 AM
There is no easy way on the 2900 series like the catalyst 4500 series . You can use the show int stats command and anything that show "0" for input you know it hasn't been used but it would not account for any line that may have been connected previously and then disconnected. Why they don't put the 4500 command "show interfaces link" into all their switches is beyond me , maybe its a hardware issue.
06-23-2009 09:47 AM
logging event link-status
show log
