04-07-2008 05:37 AM - edited 03-05-2019 10:14 PM
Hi all, if I ping a device on another subnet that is connected to my distribution switch, will my switch learn the mac address of the device in the other subnet along the trunk link? I assume it will not ?
04-08-2008 12:32 AM
can anyone help here at all?
just to add, I mean the trunk link from my switch to the distribution switch, which is not a member of the vlan on the other side.
thanks
04-08-2008 02:49 AM
It depends upon u r toplogy .ie how u r doing u r intervlan routing usually the mac address will be learned on the trunk links.
Mahmood
04-09-2008 03:31 AM
the vlans are seperated by the dist switch, the vlan for that side only exsist on the trunk link needed. ie vlan 2 on one side, vlan 3 on the other,
if im right vlan 2 mac addresses should not be on trunk or switches on vlan 3, is this correct ?
04-09-2008 12:04 PM
No, devices in one VLAN will not learn the MAC addresses in another VLAN, since to cross VLANs they have to be routed.
