09-03-2020 04:14 AM
Hello
In the attachment you will see my topology
I have 4 routers and two switches
my question what is best way to make this setup redundant ?!!
I will use GRE tunnel between all routers and I need to know what is the best way to redundant switches ?!
Best Regards
09-03-2020 04:36 AM
You need to bit Ground work here :
1. you can run HSRP between Routers. ( connect R1 and R2 in the Switch) - i would suggest to replace Hub with switch.
2. is your switch acting Layer 2 ?
3. You can have tunnel between R1 to R1 and R2 to R2 ( rather mesh ) - this is my personal opinion.
4. are the internet going vial same ISP or different ISP ? - then if the ISP go down ? both VPN go down any way.
make sense ?
09-03-2020 05:42 AM - edited 09-03-2020 05:44 AM
Thanks for answer actually the hub is now a Mikrotik router yes the switch is L2 and there is another switch that I have to add also for redundancy
so Hub and Internet they are Mikrotik routers
When I configure R1 and R1 or any two cisco routers do I have to use a switch ?
Look please to the attachments and this is what I have exactly in my house but I need to add more R2 cisco router and another GRE cisco router and Switch and I got all devices but I want to know to do the redundancy
I was thinking the other gre tunnel cisco beside the first one with two links one to the MT internet and the other to the HUB but Ihow I can configure redundancy with the R1 and the Switch I have to add R2 to R1 and another switch to SWI
09-03-2020 05:44 AM
