12-11-2014
04:31 AM
- last edited on
03-25-2019
04:31 PM
by
ciscomoderator
Can switches SG500XG-8F8T in a stack do multichassiss LACP aggregation?
Example: I want connect server with two XG NICs to stack made by switches SG500XG-8F8T. Due to high availability the first NIC should be connected to the first switch and the second NIC to the second switch. Is it possilbe? Or have I to use 3750 series switches or similar?
Thanks Martin
12-11-2014 06:27 AM
Pretty sure ive done this before.
the 'High Availability and Resiliency' section and 'True Stacking' section will help you out.
12-16-2014 05:13 AM
Hmm, there is no exact info about LACP in stack in these paragraphs. I must to believe you. ;-)
01-12-2015 11:44 PM
Yes, these switches function as true stacks which means it functions as a single unit:
- Single STP domain
- Single RMON Agent
- You can link aggregate across units in the stack
- You can port and VLAN mirror across units in the stack
- Unified control and Management planes
etc.
