Switches Stack
Zaki-93
Community Member
Hi Everyone,
Can I stack 9300 switches with 3750 switches?
Thank you.
Hello
@Zaki-93 wrote:
the old switch I have is 3750 and I will add the Cat 9300 so I need to link them together.
is it gonna work if I established layer 2 port-channel between them?
Yes it is, just make sure the port-channel have the same settings ( ie - trunk, native vlan, link modes (active or on )
Kind Regards
Paul
5 Replies 5
Mark Elsen
       - Nope ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
The answer is NO., they are different families of switches, One going to fade from the market soon (3750) - Cat 9300 born for the new world.
Instead, you can establish Layer 2 or Layer 3 port-channel between them.
BB
Hello
Kind Regards
Paul
yes, sure this is what I have suggested since you can not stack, so you can establish Layer 2 or Layer3, Hope this helps.
BB
