switches - trunk link
kcsureshbabu
How to remove particular vlan in trunk link?
Jan Hrnko
Level 4
Level 4
Let's say you want to remove vlan 69 from interface fa0/1
Switch(config)#interface fa0/1
Switch(config-if)#switchport trunk allowed vlan remove 69
Switch(config-if)#end
gentleman above is right, however if you want to know all the possibilities that you have, take a look at the command itselft and syntax description:
switchport trunk allowed vlan vlan_list
Syntax Description
vlan-list format is all | none | [add | remove | except] vlan-atom [,vlan-atom...] where:
all
specifies all VLANs from 1 to 4094. This keyword  is not allowed on  commands that do not permit all VLANs in the list to  be set at the same  time.
none
means an empty list. This keyword is not allowed  on commands that require certain VLANs to be set or at least one VLAN to  be set.
add
adds the defined list of VLANs to those currently  set instead of replacing the list. Valid IDs are from 1 to 1005;  extended-range VLANs (VLAN IDs greater than 1005) are valid in some  cases.
except
lists the VLANs that should be calculated by  inverting the defined list of VLANs. (VLANs are added except the ones  specified.) Valid IDs are from 1 to 1005. Separate nonconsecutive VLAN  IDs with a comma; use a hyphen to designate a range of IDs.
remove
removes the defined list of VLANs from those  currently set instead of replacing the list. Valid IDs are from 1 to  1005; extended-range VLAN IDs are valid in some cases.
vlan-atom
is either a single VLAN number from 1 to 4094 or a  continuous range of VLANs described by two VLAN numbers, the lesser one  first, separated by a hyphen.
Best regards,
Jan
shanilkumar2003
Switchport trunk remove vlan ..
Rasika Nayanajith
Swithport trunk allow vlan remove command under interface config
Jan Hrnko
Level 4
Level 4
Syntax Description
all
none
add
except
remove
vlan-atom
Best regards,
Jan
