Switching QOS.
ajay chauhan
Level 7
Level 7
Hey Guys,
can someone please explain how internal cos-to-dscp and dscp-to-cos map works ?
https://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_58_se/configuration/guide/swqos.html#wp1157930
lets say a ip phone is connected to access switch and interface is configured as cos trust .In this case cos-to -dscp map will be used on ingress port ,I read somewhere these dscp values are internal/within switch.
If a router is connected to this switch and I want to match EF/46 how does switch mark this packet to use DSCP value ?
how many times maps are used within switch ?
Just trying to understand internal process of qos on switch
Ajay
acampbell
Ajay,
Have a look at page 7
Figure 37-3 Classification Flowchart
on this link
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/swqos.pdf
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Thanks for Reply.
I understand this doubt comes if the dscp values genrated by cos-dscp map is internal to switch then how can I match the same on next hop router.
So what would be diffrence between internal dscp and dscp .
Ajay
cadet alain
the outgoing DSCP value will be 40 due to Cos to DSCP mapping default and so you must either:
-disable DSCP rewrite: no mls qos rewrite ip dscp
- modify Cos to DSCP map: mls qos map cos-dscp
- trust on DSCP: mls qos trust dscp
Regards.
Alain
