Switching Throughput for WS-C3550-48-EMI
shimabuku
What is the switching throughput for the WS-C3550-48-EMI? According to Cisco datasheet, it's 6.8 Gbps maximum forwarding bandwidth. Reason I am asking is because I currently have a CISCO2911/K9 as a router on a stick and it has a switching throughput of 180.73 Mbps. The 2911 is connected to a WS-C2970G-24TS-E where a few servers are connected. I want to replace the WS-C2970G-24TS-E with two existing WS-C3550-48-EMI and do intervlan routing with CEF enabled. Put the 2970 down at the access layer. What do you guys think, is this a better design?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Where are you seeing that?  From the datasheet I see: "13.6 Gbps switching fabric (Catalyst 3550-48)" and "10.1 Mpps forwarding rate for 64-byte packets (Catalyst 3550-48)" (I also see same values on an old switch performance comparison sheet, http://www.cisco.com/web/partners/downloads/765/tools/quickreference/switchperformance.pdf.
Use the 3550 as a router on a stick forming a dual gig Etherchannel with the 2970G.
