switching troubleshooting
vkarthik.cs
Community Member
Error Message:%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error,  Interface <interface> Power Controller reports power Imax error  detected
I am having c2960 switch with sw release version
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44r)SE4, RELEASE SOFTWARE (fc1)
in which for solution of error, when i configure
switch#conf t
switch(config)#int fa0/20
switch(config-if)#power inline ?
  auto         Automatically detect and power inline devices
  consumption  Configure the inline device consumption
  never        Never apply inline power
  police       Police the power drawn on the port
  static       High priority inline power interface
anyone there, i am getting more error messages by this,,,,,,,,please help me.
5 Replies 5
Giuseppe Larosa
Hello Karthik,
is anything connected to the port?
the message says that the maximum electrical current that can be sent out of the port has been detected.
If nothing is connected to the port I would say it is a bug as an unconnected port is an open circuit for POE.
If a POE device is connected to the port, the message may be meaningful/true
Hope to help
Giuseppe
Sir,,
          I didnt any connect any device on this port. Now may you guide me now.
Hello Karthik,
if the port is unplugged the message is unreal.
I would consider an IOS upgrade
Hope to help
Giuseppe
So i should upgrade IOS right??
HI Karthik,
This error indicates that PD is drawing over-current more than allowed/supported per IEEE 802.3af standard.
Whats the firmware version you are running?
If you are running any thing lesser than  12,2(55)SE3 , 12.2(58)SE1 then I request you to kindly discus with your account team and plan for the upgrade.
Inayath
