10-30-2012 02:40 AM - edited 03-07-2019 09:45 AM
I manage a network with a ghost server, a 3750G, several outside access, and some vlans.
This is a very simplify view of this network:
I'm facing an unusual problem for me as I build these kind of config since a long time without any problem.
The ghost server is on all vlans connected to a trunk port on the 3750G which is used as a central switch and for basic routing.
All equipements connected to vlans 1, 2 or 3 are on 2950 switchs themselves connected to the 3750G on dedicated access ports, each
in there respective vlans.
All equipements connected to vlans 1, 2 or 3 have as gateway a vlan interface on the 3750. (10.0.x.3)
All the vlan interfaces have route-maps applied on them to redirect traffic to their dedicated outside access.
The route-maps match only traffic destinated to the outside.
Everthing is working well but the multicast.
When I create a ghost session on the server, I can see computer connecting on it, but the multicast never start.
If I use directed broadcast it works with good perfs, but the CPU processes of the 3750 go high because of the IP Input (Till 99%).
If I remove the route map from the vlan interface which is on the ghosted network, the multicast works but with poor perfs.
If I shutdown the vlan interface the multicast works well with good perfs.
It seems my problems are tied with the Vlan interfaces but I don't know why.
This is a sample of the config:
switch 1 provision ws-c3750g-24ts-1u
system mtu routing 1500
vtp domain SM
vtp mode transparent
ip routing
no ip domain-lookup
ip domain-name SM-Net
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.1.1 10.0.1.200
ip dhcp pool Salle-1
network 10.0.1.0 255.255.255.0
default-router 10.0.1.3
dns-server 10.0.1.1
errdisable recovery cause channel-misconfig (STP)
errdisable recovery interval 30
spanning-tree mode pvst
vlan 101
name Net-1
interface GigabitEthernet1/0/25
description Connected_to-Switch-Net-1
switchport access vlan 101
switchport mode access
switchport nonegotiate
interface Vlan101
description Net-1
ip address 10.0.1.3 255.255.255.0
ip access-group Network-Rules in
ip policy route-map Network-Balancer
ip access-list extended Outside_1
deny pim any any
deny igmp any any
deny ip 10.0.0.0 0.0.255.255 10.0.0.0 0.0.255.255
permit ip 10.0.1.0 0.0.0.255 any
ip access-list extended Network-Rules
deny ip any host 10.0.1.255 log
deny pim any any
deny igmp any any
deny ip host 10.0.1.2 any
deny udp any 224.77.0.0 0.0.255.255 eq 2446
deny udp any 224.77.0.0 0.0.255.255 eq 5355
deny udp any 224.77.0.0 0.0.255.255 eq 7777
deny udp any 224.77.0.0 0.0.255.255 eq 6666
deny udp host 10.0.1.2 any (10.0.1.2 = Ghost Server)
deny tcp host 10.0.1.2 any
permit icmp any any
permit ip any any
permit gre any any
permit esp any any
route-map Network-Balancer permit 20
match ip address Outside_1
set ip next-hop 11.0.0.1
End
This is a very simplify sample of the config but all needed is in.
If someone could help it would be great.
Thx by advance for your help
FB
10-30-2012 08:49 AM
I have run in to this same situation in the past with a Ghost server in a school system with many layer 3 routes and switches.
My solution was to remove the Ghost server from the trunk and make it part of just one Vlan. Then use ip pim sparse-dense mode on all the vlan interfaces.
It would look like this.
Int Vlan1
int vlan2
int vlan3
With pim sparse-dense mode enabled on each vlan when the multicast starts it will listen to see who is actually subscribed to the stream and then send only to those port that need the stream.
10-30-2012 01:06 PM
thx for your answer.
So if I understand what you mean, the multicast will be routed through the 3750?
Usually with the config I explained in my first post I have a throughput which goes till 2500MB/min sometimes more. (except for this time)
With the multicast routed will I have the same throughputs?
Thx again for your help.
FB
10-31-2012 11:05 AM
yes the pim command will allow multicast traffic to be routed over a layer 3 interface.
02-14-2013 01:58 AM
I still have the problem.
Before move the Ghost server in a separate Vlan I want to be sure that will be the solution.
Because even if I move the Ghost server in a separate vlan, the route maps will still there as
users un vlan 1,2,3 has their own internet access.
I Tried several solutions but none really helped.
The best I had was to put a deny ip 224.77.0.0 0.0.255.255 int the ACL match by the route-map, but this make the ghost
multicast work with very low perf because of a High loading CPU.
I updated the IOS but it did not helped.
What is very strange is that config work very well on an another switch (3750-X)
Thx for your future help and comment.
F.B.
02-14-2013 12:38 PM
Finally!! I found the solution.
No need to disable the trunk on the server.
This paper lead me to the solution: http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008059a9df.shtml
Quickly it explain that the edge switchs don't inform their backbone SW about their multicast receivers if an mrouter is not configured on the edge switchs.
A way to do it is to activate Multicast distributed switching:
ip multicast-routing distributed
In global config mode
then
directly on the vlan interfaces.
This way the backbone switch inform the edge switchs that it is the querier, so they informe their backbone switch about their receiver.
Sorry for my bad english, I hope that is clear enough.
Bye
F.B.
