09-11-2022 10:35 PM - edited 09-11-2022 10:45 PM
Will Cisco catalyst 1000 series switch Support third-party Extream SFP module?
Anyone please! suggest me for this troubleshooting.
Solved! Go to Solution.
09-11-2022 11:23 PM
09-11-2022 11:19 PM - edited 09-11-2022 11:20 PM
first of all cisco not recommends to connect other SFPs to cisco switches. but you can try, if Code base is compatible, it will work. also you can try enabling unsupported SFP using below commands
service unsupported-transceiver
no errdisable detect cause gbic-invalid
09-11-2022 11:23 PM
