09-16-2021 01:50 AM
hello,
how i can make switchover and reload between two supervisor of C6509 !
and if i make switchover did automatically the standby supervisor will be active and then will return !
thanks in advance.
09-16-2021 04:27 AM
Not sure if i understood the question correctly, you would like switch over from Active to Stanby and back it back to Active when active back ?
the switch over need to done manually, by reloading or force switch over. explain below as steps : (hope is that what you looking ?)
09-17-2021 09:16 AM
thanks for your replay @balaji.bandi
i have a switch witch one supervasor and i will integrate a other supevisor and create HA
So i would know in Catalyst should choose the mode ( RPR, RPR+ or SSO) or it's a optional and there are another confige
and what's is the steps ?
thanks!
09-17-2021 09:38 AM - edited 09-17-2021 09:40 AM
When you have 2 sups in a chassis, you want to configure them as SSO. This way, the failover is very fast. Once configured, verify with the command "show redundancy". One sup should be active and the backup sup should be in "hot standby" mode.
09-17-2021 09:44 AM
09-17-2021 10:00 AM
There is RPR too but SSO works best.
For more info, have a look at the link I posted.
09-17-2021 10:00 AM
You can find each one more descritive
Most cases i have used NSF/SSO - Cat 6K with Sup 720 and Su2T
