Switchport configuration
wanhwai
Community Member
(WS-C3550-24-EMI)
interface GigabitEthernet0/1
switchport access vlan 20
switchport mode dynamic desirable
spanning-tree portfast
end
interface Vlan20
ip address 168.X.X.13 255.255.0.0
no ip redirects
standby 20 ip 168.X.X.14
standby 20 timers 1 4
standby 20 preempt
end
(WS-C3750G-24T-S)
interface GigabitEthernet1/0/11
switchport access vlan 101
switchport mode access
no ip address
duplex full
speed 1000
interface Vlan101
ip address 168.X.X.101 255.255.0.0
Hi all,
WS-C355024-EMI is connected to WS-C3750G-24T-S as uplink with the respective port shown above.
The C3750 is the distribution switch for server and C3550 is the Core swicth that do inter vlan routing.
I wonder why this 2 switch still can talk to each other although the individual port is accessing diffrent VLAN.
Please help. Thank you.
Steve
5 Replies 5
globalnettech
Level 9
Level 9
Hello Steve,
which IP addresses are you using for your Vlan 20 and 101 ? From what you have posted, it looks like they are both in the same 168.X network, can you verify that ?
GNT
Yes both int vlan are using the same 168.0.0.X netowork.
My concern is how come this still work although 2 ports are accessing diffent VLAN.
THANK YOU
I beleive that this is because of "switchport mode access" command on the second switch.
Trunk negotiation fails so both ports are actually in access mode. Packets are not marked with VLAN tag so when 3550 receives packet on its port it beleives that packet belongs to VLAN 20 and sends it further in VLAN 20.
//Mikhail Galiulin
Is it common to configure the port in this way?
michaelfoote
Community Member
Steve,
Mikhail is correct. The switchport mode access command tells the port to not VLAN tag the packets as they pass through. The switchport mode trunk command would tag the packets with the VLAN ID which would cause them to be discarded at the other interface.
Hope this helps,
Mike
