Switchport Mirroring Question
carbonscoring
Hi, I have a webfilter server that I have set up out of band. In previous installs I've always had the server connected to a the same switch that my firewall was comming in on.
However this time the server is located on another access switch. I'm having issues configuring or how I should configure the SPAN port. Since the source port that I'm monitoring is not on the same switch as the destination port I'm unsure if I should source the Vlan that its comming in on or the trunk port its comming in on or if there is another method. Here's what I added to the access switch that is attached to the server:
monitor session 1 source interface Gi0/1
monitor session 1 destination interface Fa0/17 ingress vlan 1
I'm attaching a jpeg that shows physical/logical of the network.
please any help,
thanks,
Mike
yagnesh_tel
You will need RSPAN for this as source ports and destination ports are distributed across multiple switches. You should create an RSPAN VLAN before configuring an RSPAN source or destination session.
Follow this guideline:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_13_ea1/configuration/guide/swspan.html#wp1081130
yagnesh_tel
