switchport mode dynamic desirable
rsamuel708
Are there any pitfalls of having this command on interfaces that will never be used for trunks? i.e. any unneeded traffic etc.
Thanks in advance.
/rls
5 Replies 5
Edison Ortiz
They can actually become trunking interfaces if connected to another switch with mode desirable or mode auto
If you don't want to ever have those interfaces in trunking mode, change it to mode access
HTH,
__
Edison.
The majority of our switch interfaces are configured as such:
interface FastEthernet1/0/6
switchport access vlan 120
duplex full
speed 100
spanning-tree portfast
...so in this case, I should just be removing the 'switchport mode dynamic desirable' line, correct?
/rls
Removing the line won't fix the problem.
The switchport needs to have a mode to run on. It depends on the hardware but removing the line may set your switchport to dynamic auto. If you are connecting to hosts, the recommended macro to run is switchport host
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_46_se/command/reference/cli3.html#wp1948119
HTH,
So just to be clear, the 'switchport host' command will replace the other command in the configuration once I enter it in config mode?
/rls
switchport host is a macro. The command is clearly explained on the link I posted. If the commands that are part of the macro are already under the switchport, they won't be removed. It's like a copy and paste of a template that you may have.
__
Edison.
