Showing results forĀ
Search instead forĀ
Did you mean:Ā
switchport mode trunk not showing in running configuration
ring_gt
We have s 6506-E that needed to be powered down due to a maintenance.
After it booted up, we noticed that the configuration "switchport mode trunk" disappeared from the
configuration under one of the port channels (including its member interfaces) , even though "show startup" shows it is there. We confirmed the configuration in the show startup is the one that was loaded after the reboot.
show startup result
interface Port-channel4
switchport
switchport trunk allowed vlan 197,198
no ip address
show running result
switchport
no ip address
Aside from this, the operation of the etherchannel is working fine, and is displaying as a trunk.
It is not a big issue, I am just wondering if there is a bug or something.
We are running on an old IOS version as well:
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF9, RELEASE SOFTWARE (fc1)
Abheesh Kumar
I think it may be a bug, If you have maintenance window try to upgrade and see but check this Field Notice: FN - 63743 before doing upgrade.
Abheesh
Reza Sharifi
It appears to be a cosmetic bug as the EtherChannel is working fine.
The IOS you are running (12.2(18)SXF9) is over 10 years old.  So, is it probably time to upgrade.
