Switchport trunk allowed vlan
Jerry Ayers
          I have a port channel that is set up as a trunk. I currently am allowing certain vlans but would like to change it to add another vlans. I want to know if I change it will I experience any down time.
Example
(Current Port-channel and ports)
interface Port-channel1
switchport
switchport trunk native vlan 50
switchport trunk allowed vlan 1,25,30,35,50,192
switchport mode trunk
no ip address
spanning-tree portfast trunk
spanning-tree bpduguard enable
interface TenGigabitEthernet8/1
switchport
no ip address
channel-group 1 mode on
interface TenGigabitEthernet9/1
switchport
no ip address
I want to change by using these commands
conf t
switchport trunk allowed vlan add 10
Should I expect to experience any down time.
mfurnival
Level 4
Level 4
No, you can use the "add" command and it will not disrupt traffic.
Bilal Nawaz
Hello, down time is minimal, and its good you are taking note of this down time if you do not use the key word, you are also correct with the 'add' command, this is a key word in the command where it will add the vlan instead of removing all the vlans and re-applying them to the trunk.
Lets say I have a trunk and its already trunking vlans from 5 - 100. I want to add vlans 1,2,3 to the trunk.
If you was to do this e.g
Switchport trunk allowed vlan 1,2,3,5-100
This would temporarily remove all vlans and re-apply the vlans on the trunk.
But instead of just doing this you can do this:
Switchport trunk allowed vlan add 1,2,3
The trunk will then be configured to cater for the additional vlans without removing the vlans, and results in 0 downtime.
This is specified by the 'add' key word. Also there is a 'remove' key word if you want to remove vlans from the trunk
NOTE:
In your case you only need to apply the add command to the port channel interface, not the physical interfaces!
I.e.
conf t
Then this configuration will also take effect on the port channel members.
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
