SYSLOG LOGGING PROBLEMS !!!!
dukenukem
Hi ALl,
I am trying to configure a syslog server to log messages from the routers.
I am trying on the first router, and i issue the command :
LOGGING (syslog ip address)
So now the messges should be sent to the syslog server.
Now supposingly i want to capture the events when an access-list is met namely the DENY IP ANY ANY .... so i should issue the DENY IP ANY ANY LOG command right ??? the LOG keyword should force the router to log the event every time this is met. However i try to do illegal traffic to trigger the DENY IP ANY ANY LOG but it does not show anything logged in the show run, or on the syslog server.
I know the syslog works fine as it logs the messages
that i have configured the router from my ip address.
Is there something i am missing here ???
Please help ,
George
What trap level have you set on the router??? After going in the configure terminal mode issue the command "logging trap 7" so that you'll get all the messages which are sent.
If would be better if you could post your config.
Hope it helps.
Please rate helpful posts.
AbhisheK
Ok..it seems to work fine now.
thanks a bunch....
George
You are welcome.
Please rate all helpful posts.
AbhisheK
