Syslog Severity Priority
johnlloyd_13
Level 9
Level 9
hi all,
just a sanity check here. i would like to know which syslog severity is the highest (priority)? is it emergency or debugging? thanks in advance!
Jennifer Halim
The lower the number the more severe the problem is.
Emergency is level 0, and debugging is level 7.
Here is the list of severity for your reference:
http://www.cisco.com/en/US/docs/ios/system/messages/guide/sm_cnovr.html#wp73943
Jennifer Halim
Hi Jennifer,
Thanks for your feedback! Sanity checked!
