how to Block Gtalk with ACL on the switch port level
i am trying to create an ACL to block Gtalk on one swithc port only for a single user , below is show version of the switch and switch port configurations
Cisco IOS Software, C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 15:26 by nachen
Image text-base: 0x00003000, data-base: 0x01A00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
SW01 uptime is 6 weeks, 1 day, 18 hours, 39 minutes
System image file is "flash:c3560-advipservicesk9-mz.122-46.SE/c3560-advipservicesk9-mz.122-46.SE.bin"
SW01# sh run int Gi0/18
Building configuration...
Current configuration : 353 bytes
interface GigabitEthernet0/18
switchport access vlan 19
switchport mode access
switchport voice vlan 18
switchport port-security maximum 3
switchport port-security violation protect
switchport port-security aging type inactivity
storm-control broadcast level 1.00
spanning-tree portfast
end
i know i have to create an extended ACL in order to block the same but the thing is i tried the same but it didnt work , any idea.
Regards.
WOW, 80 Views and no one reply interesting
Can you resolve talk.google.com into an IP then block that IP using an ACL?
Or maybe you could modify the persons machine host file to something like this :
127.0.0.1 talk.google.com
127.0.0.1 talkx.l.google.com
here is the address
C:\>ping talk.google.com
Pinging talk.google.com [74.125.71.125] with 32 bytes of data:
Reply from 74.125.71.125: bytes=32 time=450ms TTL=46
Reply from 74.125.71.125: bytes=32 time=431ms TTL=46
Reply from 74.125.71.125: bytes=32 time=446ms TTL=46
Reply from 74.125.71.125: bytes=32 time=285ms TTL=46
Ping statistics for 74.125.71.125:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 285ms, Maximum = 450ms, Average = 403ms
C:\>ping talkx.l.google.com
Pinging talkx.l.google.com [74.125.65.125] with 32 bytes of data:
Reply from 74.125.65.125: bytes=32 time=243ms TTL=51
Reply from 74.125.65.125: bytes=32 time=230ms TTL=51
Reply from 74.125.65.125: bytes=32 time=235ms TTL=51
Ping statistics for 74.125.65.125:
    Minimum = 230ms, Maximum = 243ms, Average = 237ms
C:\>
i will try to create an ACL for the same and will share the result with you,
for the host file it quite hard to do it since its not allowed to use $ share in my Company for any reason
