System returned to ROM by power cycle at 23:31:24 PDT Thu Sep 27 2007 (SP by power on)
sandeeprgec
Hello Team,
Today i got one case regarding the Router reboot. Output pasted below.
------------------ show version ------------------
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE8, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
GUJVODR4CCR02C7609 uptime is 44 minutes
Uptime for this control processor is 44 minutes
System restarted at 07:20:12 IST Fri Jun 5 2015
System image file is "bootdisk:c7600s72033-advipservicesk9-mz.122-33.SRE8.bin"
Last reload type: Normal Reload
where it's showing the Reload was normal reload.
 system restarted time was 07:20:12 IST Fri Jun 5 2015
But the above line what does that mean ?,, what it signifies...
"System returned to ROM by  power cycle at 23:31:24 PDT Thu Sep 27 2007 (SP by power on)" Kindly elaborate. why it's showing the previous date of 2007.
thanks
Sandeep
5 Replies 5
InayathUlla Sharieff
Do you have redundance Sup module on this box?
If yes the system restarted basically may be the Active Sup. (I mean to say the SUp failover might had hapen and not the complete switch reloaded at this point of time).
Can you please paste:-
show ver
show module
show redundancy
show logs
regards
Inayath
Hi Inayath,
thanks for the quick reply,
there is no redundant Sup.
------------------ show module ------------------
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1128UHFF
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL13442RSZ
  4    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1752JQMV
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1131WBNJ
  6   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1330ULKX
  8   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1814PPUL
  9   11  7600 ES+                               76-ES+XC-20G3C     JAE14530LO1
rest of the output attached.
It looks to me cosmetic bug.
I will share in case if I find it today.
REgards
Inayath
Here you go:-
Bug:- CSCeh49742
Link:
https://tools.cisco.com/bugsearch/bug/CSCeh49742/?reffering_site=dumpcr
Inayath
*Plz dont forget to rate all usefull posts.
Hi Inayath,
you mean to say that this is a cosmetic bug.
but already we are running a Higher release on cisco Router..
GUJVODR4CCR02C7609#show version
please advise on this.
