TACACS and enable password
subharojdahal
hi folks.
I am able to login to my router VIA TACACS+ server. My username and password doesnot work with enable mode. When I do enable after login to user prompt; it just throws me "Authentication failed" message.
AAA commands used
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
I set up TACACS+ server and key as it has been working with login.
I really appreciate if any one can help in this issue.
rgrds
subharose
Yudong Wu
Level 7
Level 7
I don't have ACS server in hand right now. But I believe that you need turn on something on ACS server so that you can have TACACS+ to authenticate on enable password. Just enable all TACACS+ feature under "Interface" then go throught each feature you have under user configuration to see which one might be related to it.
5 Replies 5
Yudong Wu
Level 7
Level 7
thanks
I will try it now.
thanks buddy
thumb's up for you.
Thanks, You are so quick. :)
glen.grant
You have it set up to use the enable secret or enable password for enable mode so you will have to use that otherwise change the second line so that the end also reads local instead of enable.
