TACACS authorization method
tedauction
Hello, I am seeing some strange behaviour on my switch running TACACS.
Sometimes when command are authorized on my TACACS.net server, they do not include the actual command requested for authorization in the logs. Other times it does.
Here are examples of debug logs from TACACS.net server:
A COMMAND AUTHORIZATION WHERE THE ACTUAL COMMAND SHOWS IN THE LOGS: (nb. I have indicated differences commented with ******). The main difference seems to be the 'Authorization method i.e. a method of DEBUG logs the command correctly, while a method of TACACSPLUS does not. Does anyone have any insight ?
Received:
MajorVersion=12
MinorVersion=0
Type=Authorization
SeqNum=1
IsEncrypted=True
IsSingleConnect=False
SessionID=-273089716
DataLength=99
Authorization Method=Debug*******************
Priv lvl=1
Auth Type=Ascii
Service=None***************DIFFERENCE
User=lastresort
Port=tty3
Rem Addr=10.15.2.131
Args: service=shell cmd=show cmd-arg=cdp cmd-arg=neighbors cmd-arg=<cr>*********DIFFERENCE
<87> 2018-05-27 11:46:46 [10.21.8.5:58174] Authorization Entry #1 is being applied based on Client configuration
<87> 2018-05-27 11:46:46 [10.21.8.5:58174] Command show cdp neighbors <cr> passed expression .* (internal:^[\a\b\t\r\v\f\n\e\s]*.*[\a\b\t\r\v\f\n\e\s(<cr>)]*$), Allow=True
<87> 2018-05-27 11:46:46 [10.21.8.5:58174] Received 2 packets on connection
Sending:
MajorVersion=12
MinorVersion=0
Type=Authorization
SeqNum=2
IsEncrypted=True
DataLength=6
Authorization Status=PassAdd
User=
Port=
Args:
A COMMAND AUTHORIZATION WHERE THE ACTUAL COMMAND DOES NOT SHOW IN THE LOGS:
Received:
MajorVersion=12
MinorVersion=0
Type=Authorization
SeqNum=1
IsEncrypted=True
SessionID=-1726325463
DataLength=52
Authorization Method=TACACSPLUS*****************DIFFERENCE
Priv lvl=1
Auth Type=Ascii
Service=Login*******************DIFFERENCE
User=lastresort
Port=tty1
Args: service=shell cmd**********DIFFERENCE
<87> 2018-05-27 11:54:27 [10.21.8.5:53709] Authorization Entry #1 is being applied based on Client configuration
<87> 2018-05-27 11:54:27 [10.21.8.5:53709] Client asked for AutoExec pairs. Returning PassAdd
<87> 2018-05-27 11:54:27 [10.21.8.5:53709] Received 2 packets on connection
Sending:
MajorVersion=12
MinorVersion=0
Type=Authorization
SeqNum=2
IsEncrypted=True
DataLength=18
User=
Port=
Args: priv-lvl=15
Here is my TACACS configuration:
aaa new-model
aaa authorization console
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+
enable aaa authorization exec default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
ip tacacs source-interface Vlanx
tacacs-server host 10.21.250.212
tacacs-server timeout 10
tacacs-server key <xxx
0 Replies 0
