04-23-2012
01:54 AM
- last edited on
03-25-2019
04:19 PM
by
ciscomoderator
i have the following issue:
i can authenticate to my tacacs+ server, but authorization is not working
i have cross referenced the config with other routers but this one doesn't seem to work
i can login, so authentication works, then i do a "show run" or "whatever command" and it says "authorization failed" plus a long time wait
here the tacacs+ and aaa debugging
170325: Apr 23 09:52:12.907 Asd: TAC+: Opening TCP/IP to 10.60.12.88/49 timeout=5
170326: Apr 23 09:52:17.906 Asd: TAC+: TCP/IP open to 10.60.12.88/49 failed -- Connection timed out; remote host not responding
170327: Apr 23 09:52:17.906 Asd: AAA/AUTHOR (1505455504): Post authorization status = ERROR
170328: Apr 23 09:52:17.906 Asd: tty194 AAA/AUTHOR/CMD(1505455504): Method=LOCAL
170329: Apr 23 09:52:17.906 Asd: AAA/AUTHOR/LOCAL: no entry for username111
170330: Apr 23 09:52:17.906 Asd: AAA/AUTHOR (1505455504): Post authorization status = ERROR
170331: Apr 23 09:52:17.906 Asd: tty194 AAA/AUTHOR/CMD(1505455504): Method=NOT_SET
170332: Apr 23 09:52:17.906 Asd: tty194 AAA/AUTHOR/CMD(1505455504): no methods left to try
170333: Apr 23 09:52:17.906 Asd: AAA/AUTHOR (1505455504): Post authorization status = ERROR
170334: Apr 23 09:52:17.906 Asd: AAA/MEMORY: free_user (0x634E9E8C) user='user111' ruser='routername' port='tty194' rem_addr='1.1.1.1' authen_type=ASCII service=NONE priv=15 vrf= (id=0)
170335: Apr 23 09:54:00.288 Asd: AAA: parse name=tty194 idb type=-1 tty=-1
170336: Apr 23 09:54:00.288 Asd: AAA: name=tty194 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=194 channel=0
170337: Apr 23 09:54:00.288 Asd: AAA/MEMORY: create_user (0x636AC9FC) user='username111' ruser='routername' ds0=0 port='tty194' rem_addr='1.1.1.1' authen_type=ASCII service=NONE priv=15 initial_task_id='0', vrf= (id=0)
170338: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): Port='tty194' list='' service=CMD
170339: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/CMD: tty194(3078002889) user='username111'
170340: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): send AV service=shell
170341: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): send AV cmd=show
170342: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): send AV cmd-arg=running-config
170343: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): send AV cmd-arg=<cr>
170344: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): found list "default"
170345: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): Method=ACS (tacacs+)
170346: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/TAC+: (3078002889): user=username111
170347: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/TAC+: (3078002889): send AV service=shell
170348: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/TAC+: (3078002889): send AV cmd=show
170349: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/TAC+: (3078002889): send AV cmd-arg=running-config
170350: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/TAC+: (3078002889): send AV cmd-arg=<cr>
170351: Apr 23 09:54:00.288 Asd: TAC+: Using default tacacs server-group "ACS" list.
170352: Apr 23 09:54:00.288 Asd: TAC+: Opening TCP/IP to 10.60.12.88/49 timeout=5
170354: Apr 23 09:54:05.291 Asd: TAC+: TCP/IP open to 10.60.12.88/49 failed -- Connection timed out; remote host not responding
170355: Apr 23 09:54:05.291 Asd: TAC+: Opening TCP/IP to 10.60.12.88/49 timeout=5
170356: Apr 23 09:54:10.291 Asd: TAC+: TCP/IP open to 10.60.12.88/49 failed -- Connection timed out; remote host not responding
170357: Apr 23 09:54:10.291 Asd: AAA/AUTHOR (3078002889): Post authorization status = ERROR
170358: Apr 23 09:54:10.291 Asd: tty194 AAA/AUTHOR/CMD(3078002889): Method=LOCAL
170359: Apr 23 09:54:10.291 Asd: AAA/AUTHOR/LOCAL: no entry for username111
170360: Apr 23 09:54:10.291 Asd: AAA/AUTHOR (3078002889): Post authorization status = ERROR
170361: Apr 23 09:54:10.291 Asd: tty194 AAA/AUTHOR/CMD(3078002889): Method=NOT_SET
170362: Apr 23 09:54:10.291 Asd: tty194 AAA/AUTHOR/CMD(3078002889): no methods left to try
170363: Apr 23 09:54:10.291 Asd: AAA/AUTHOR (3078002889): Post authorization status = ERROR
i can ping both tacacs+ servers from within their vrf, using the source interface, so connectivity is good, no firewalls in between
authentication works, just authorization not, with a large timeout
any ideas?
sh ver
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.3(8)T8, RELEASE SOFTWARE (fc1)
key is also good as i can authenticate
tacacs+ server also is set to accept from the correct ip address, i.e. the source address of the interface on the router
04-23-2012 09:32 AM
i know i clicked it and my version was also there
i might upgrade it and see how that works
04-24-2012 01:08 AM
i upgraded to 12.4(25f) adv ip services and reloaded
issue is GONE!
thanks for thinking along guys
