Tacacs+ authorization not working
axeleratorcisco
i have the following issue:
i can authenticate to my tacacs+ server, but authorization is not working
i have cross referenced the config with other routers but this one doesn't seem to work
i can login, so authentication works, then i do a "show run" or "whatever command" and it says "authorization failed" plus a long time wait
here the tacacs+ and aaa debugging
170325: Apr 23 09:52:12.907 Asd: TAC+: Opening TCP/IP to 10.60.12.88/49 timeout=5
170326: Apr 23 09:52:17.906 Asd: TAC+: TCP/IP open to 10.60.12.88/49 failed -- Connection timed out; remote host not responding
170327: Apr 23 09:52:17.906 Asd: AAA/AUTHOR (1505455504): Post authorization status = ERROR
170328: Apr 23 09:52:17.906 Asd: tty194 AAA/AUTHOR/CMD(1505455504): Method=LOCAL
170329: Apr 23 09:52:17.906 Asd: AAA/AUTHOR/LOCAL: no entry for username111
170330: Apr 23 09:52:17.906 Asd: AAA/AUTHOR (1505455504): Post authorization status = ERROR
170331: Apr 23 09:52:17.906 Asd: tty194 AAA/AUTHOR/CMD(1505455504): Method=NOT_SET
170332: Apr 23 09:52:17.906 Asd: tty194 AAA/AUTHOR/CMD(1505455504): no methods left to try
170333: Apr 23 09:52:17.906 Asd: AAA/AUTHOR (1505455504): Post authorization status = ERROR
170334: Apr 23 09:52:17.906 Asd: AAA/MEMORY: free_user (0x634E9E8C) user='user111' ruser='routername' port='tty194' rem_addr='1.1.1.1' authen_type=ASCII service=NONE priv=15 vrf= (id=0)
170335: Apr 23 09:54:00.288 Asd: AAA: parse name=tty194 idb type=-1 tty=-1
170336: Apr 23 09:54:00.288 Asd: AAA: name=tty194 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=194 channel=0
170337: Apr 23 09:54:00.288 Asd: AAA/MEMORY: create_user (0x636AC9FC) user='username111' ruser='routername' ds0=0 port='tty194' rem_addr='1.1.1.1' authen_type=ASCII service=NONE priv=15 initial_task_id='0', vrf= (id=0)
170338: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): Port='tty194' list='' service=CMD
170339: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/CMD: tty194(3078002889) user='username111'
170340: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): send AV service=shell
170341: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): send AV cmd=show
170342: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): send AV cmd-arg=running-config
170343: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): send AV cmd-arg=<cr>
170344: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): found list "default"
170345: Apr 23 09:54:00.288 Asd: tty194 AAA/AUTHOR/CMD(3078002889): Method=ACS (tacacs+)
170346: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/TAC+: (3078002889): user=username111
170347: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/TAC+: (3078002889): send AV service=shell
170348: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/TAC+: (3078002889): send AV cmd=show
170349: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/TAC+: (3078002889): send AV cmd-arg=running-config
170350: Apr 23 09:54:00.288 Asd: AAA/AUTHOR/TAC+: (3078002889): send AV cmd-arg=<cr>
170351: Apr 23 09:54:00.288 Asd: TAC+: Using default tacacs server-group "ACS" list.
170352: Apr 23 09:54:00.288 Asd: TAC+: Opening TCP/IP to 10.60.12.88/49 timeout=5
170354: Apr 23 09:54:05.291 Asd: TAC+: TCP/IP open to 10.60.12.88/49 failed -- Connection timed out; remote host not responding
170355: Apr 23 09:54:05.291 Asd: TAC+: Opening TCP/IP to 10.60.12.88/49 timeout=5
170356: Apr 23 09:54:10.291 Asd: TAC+: TCP/IP open to 10.60.12.88/49 failed -- Connection timed out; remote host not responding
170357: Apr 23 09:54:10.291 Asd: AAA/AUTHOR (3078002889): Post authorization status = ERROR
170358: Apr 23 09:54:10.291 Asd: tty194 AAA/AUTHOR/CMD(3078002889): Method=LOCAL
170359: Apr 23 09:54:10.291 Asd: AAA/AUTHOR/LOCAL: no entry for username111
170360: Apr 23 09:54:10.291 Asd: AAA/AUTHOR (3078002889): Post authorization status = ERROR
170361: Apr 23 09:54:10.291 Asd: tty194 AAA/AUTHOR/CMD(3078002889): Method=NOT_SET
170362: Apr 23 09:54:10.291 Asd: tty194 AAA/AUTHOR/CMD(3078002889): no methods left to try
170363: Apr 23 09:54:10.291 Asd: AAA/AUTHOR (3078002889): Post authorization status = ERROR
i can ping both tacacs+ servers from within their vrf, using the source interface, so connectivity is good, no firewalls in between
authentication works, just authorization not, with a large timeout
any ideas?
sh ver
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.3(8)T8, RELEASE SOFTWARE (fc1)
key is also good as i can authenticate
tacacs+ server also is set to accept from the correct ip address, i.e. the source address of the interface on the router
16 Replies 16
johnlloyd_13
Level 9
Level 9
hi,
can you post your show run | i aaa output?
double check the Group Setup settings on your ACS/TACACS+ server. make sure you've permitted the commands/arguments for the user/group.
aaa new-model
aaa group server tacacs+ ACS
server-private server 1 key 7 x
server-private server 2 key 7 x
ip vrf forwarding yadayada
ip tacacs source-interface FastEthernet0/0.50
aaa authentication login default group ACS local
aaa authentication login NO_AUTHEN none
aaa authorization console
aaa authorization exec default group ACS local
aaa authorization exec NO_AUTHOR none
aaa authorization commands 15 default group ACS local
aaa authorization commands 15 NO_AUTHOR none
aaa accounting exec default stop-only group ACS
aaa accounting commands 15 default stop-only group ACS
aaa session-id common
it's acs version 3.1
could you add the below and try again:
aaa authorization exec default group tacacs+
it has locked me out now
i get a direct authorization failed when i login with either my username or that of my colleague
Try to use the local database of the equipment in order to login.
After using the user from the local database paste :
show ip vrf
show ip route vrf yadayada
show run int FastEthernet0/0.50
ping vrf yadayada 10.60.12.88
Dan
i tried this
the router is connected to our core
i tried the pinging to both tacacs servers from within the vrf and fa0/0.50 as source interface
this works
hi,
AAA can be very tricky. you should've perform this on a maintenance window if this is a production router. only way to recover is to do a reboot. be sure that at least 1 user always has full rights.
i know.. it's a testrouter.. im gonna go to the DC to try access it with console cable, had to go there anyway
is a reload only option?
or is the console not subject to acs?
i stopped the acs server:
my username -> authentication failed
colleage username -> authorization failed
tacacs server back running:
my username -> direct authorization failed on login prompt
colleague -> direct authorization failed on login prompt
i checked both users in acs and they are set up exactly the same
hi,
a reboot will do.
the console line is also subjected to AAA authentication if you've set it up:
line con 0
login auth ACS
could you post the AAA config on the devices that are working properly?
Hi John ,
From the configuration pasted :
This means that the default authentication login is used the ACS group, so there is no need to use "login auth" on the line.
But if he used "login auth NO_AUTHEN" on the line con 0 , then he can get via the console line without any authentication.
Another issue via console with this will be authorization, which by default is via ACS, so there will be the need of :
Could you check the logs from the ACS, even though the 1841's logs are straigh forward :
"10.60.12.88/49 failed -- Connection timed out; remote host not responding"
Dan
Hi Dan,
You've got a good point! I might have understood the authentication interchangeably.
I would also concur with you that OP should check further the ACS policies or logs for the authorization to work.
i reloaded the router and it's back up again
which specific logging am i looking for?
i got the tacacs+ administration where i see all the commands, and the tacacs+ accounting
i don't see much strange happening there
in failed attempts i see this for my own username when i tried this morning:
CS password invalid
External DB user invalid or bad password
however i am certain i typed in my password correctly, and also reentered my password for the user
axeleratorcisco
Affected version 12.3(8)T8 - would the below apply?
CSCsa53912 Bug Details
Bug #25 of 90 | < Previous | Next >
Tacacs login is failing
Symptoms: You cannot log on when a TACACS+ server is used for authentication.
You get a message that authentication fails and you are asked again to enter
your user name.
Conditions: This symptom is observed when you make a Telnet connection to a
router that is configured for TACACS+ after you have entered you user name and
your TACACS password.
Workaround: Configure the TACACS+ single connection option by entering the
tacacs-server host host-name
single-connection command.
Status Status
Fixed
(Resolved)
Severity Severity
2 - severe
Last Modified Last Modified
In Last Year
Product Product
Cisco IOS software
Technology Technology
Authentication Protocols
1st Found-In 1st Found-in
12.3M
12.3(12.10)M
12.3(12.12)M
12.4(0.2)M
12.3(4)T13
12.3(9a)BC1
12.3(12.11)PI6
12.4(0.2)PI1a
Known Affected Versions KAV
Fixed-In Fixed-in
12.3(13)M
12.3(14.5)M
12.4(0.3)M
12.3(9a)BC3
12.3(11)T7
12.3(12.12)BC
12.3(12.12)T2
12.3(12b)M
12.4(1.8)T
Component(s) Component
aaa
Regression Regression
Y
Related Bug Information
3660/3725: TCP-2-INVALIDTCB:Invalid TCB pointer with tracebacks
Symptoms: A Cisco router shows an  invalid TCB pointer and tracebacks, and authentication stops at random:  %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x62C4512C -Process= "TPLUS",  ipl= 0, pid= 102 -Traceback= 60D60A5C 60D3DC8C  60D43F88 60B5C1CC 60B5BCAC 60B52E58 TPLUS(00003EB1)/0/NB_WAIT/628D8528:  timed out Conditions: This symptom is observed on a Cisco 3660 and  Cisco 3725 that run Cisco IOS Release 12.3(6b). Rebooting may or may not  return the router to normal behavior (that is, TACACS authentication  functions). Workaround: There is no workaround.
tacacs server is bypassed even when there is connectivity
Cannot authenticate using AAA server even when  there is connectivity. The following is configured: aaa authentication  login default group tacacs+ local Even though there's connectivity with  the AAA server as shown by successful pings,  the router does local authenticaton.
TACACS authentication fails in 12.3(123_9_BC1.041229)
Customer was running a pre-released copy of  12.3(123_9_BC1.041229) this image ould not allow him to authenticate  using Tacacs. The error was invalid character in username. without  changing the config or the tacacs sever he could authenticate  if he reverted to 12.3(9a)BC. Authentication should be working in both  versions. Workaround: use the single-connection tacacs option.  tac-server host x.x.x.x single-connection
TACACS authorization failed when perform ACQR telneting
Symptoms : The Telnet authorization failed when configure the UUT with TACACS . The telnet is ok with radius or local configuration . Condition : the problem is seen on 12.4(0.2) version Workaround : work with radius or local authorization configuration
Yes it's on the Affected versions.If you press "Known Affected Versions"  you will see the list.
Dan
