TACACS CONFIG HELP
Hi Team,
We have CISCO ASR 1002 router on our DC, I want to enable TACACS on this router.
Please can you confirm the below config or need anything?
and also i need to know what is the usage of key, we need a separate key for every device? or.
Logs;( This log fetch from other DC ASR router)
aaa new-model
aaa group server tacacs+ ACS
server xxxxxxxxxxxx
server xxxxxxxxxxxx
ip vrf forwarding Mgmt-intf
aaa authentication login default group ACS local
aaa authentication login console group ACS local
aaa authorization console
aaa authorization exec default group ACS local
aaa authorization exec console if-authenticated
aaa authorization commands 1 default group ACS local
aaa authorization commands 15 default group ACS local
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
ip source-route
ip tacacs source-interface GigabitEthernet0
deny   tcp any any eq tacacs
deny   tcp any eq tacacs any
tacacs-server host xxxxxxxxxxxx key xxxxxx
tacacs-server directed-request
Yes, configure the device in tacacs with the key, then configure the device with that tacacs server (with the same key).
You can use whatever key you like. If you want all your devices to use the same key you can do that, as long as the key matches between the tacacs server and the device.
If you have enabled some devices with TACACS and you know the key but haven't added them to the TACAS server yet, you can add these devices to your TACACS server with the key you already configured them with and it will work just fine.
-Gabriel
9 Replies 9
Gabriel Hill
Hello Senthilkumar,
Your config looks okay. Your telnet/ssh sessions will authenticate / authorize from your TACACS servers unless the ASR cannot reach them, then will authenticate / authorize from your local DB on the router. Console is set the same way, only with authorization set to automatically allow upon successful login.
My suggestions:
I normally leave the console set for local only. Also configuring "aaa authorization console" can be a little risky. I would suggest leaving console authorization off.
You said "also i need to know what is the usage of key, we need a separate key for every device?"
I assume when you say usage key you mean:
If so, the key you specify here will match the key you specify in the TACACS server for that device. If the key doesn't match, the device will not authenticate/authorize against your TACACS server.
Hope this helps,
Gabriel
Thanks Gabriel,
You mean we need do assign first KEY for this device in the TACACS server then we can config mentioned KEY in this device.
Am i right?...
We already enabled TACACS on some ASR router in other DC, Can i use the same KEY? or.
Thanks....
Senthil
-Gabriel
Thanks Gabriel,
The command "aaa authorization console" if use this one will be a problem?...
Senthil
In my personal opinion, I wouldn't recommend it. The console needs to be secure, but having it authenticate/authorize against an tacacs server can be risky (misconfiguration can lead to nightmare). I always keep the console protected with local login only, no authorization. Your config looks okay, as the authorization is set to "if-authenticated
". aaa authorization exec console if-authenticated. It has always just made me nervous to restrict the console down so much, but to each there own.
I usually add a separate authentication policy like this:
aaa authentication login LoginLocal local none
line console 0
login authentication LoginLocal
privilege level 15
- Gabriel
Thanks Gabriel,
But I can see in our other DC's they follow the same config that's why I am going to follow the same.
I have one doubt :
Can I do the config  via console or remote login.
is not be a problem right?
If any problem i need to know the local username/Password.
How to create local username password.
Thanks....
regards,
Senthil
I configured like below but still am not able to login through TACACS...
is it problem in our config or in TACACS server(ACS).
Logs;
aaa new-model
server xxxxxxxxxx
server xxxxxxxxxx
ip source-route
tacacs-server host xxxxxxxxx key 7 xxxxx
Yes you certainly need a local user account.
"username balakrishnan password example12345"
Make sure that in your tacacs server the IP address specified is the IP address associated with "GigabitEthernet0" because that's where you've configured the source interface.
TACACS has a monitoring portion where you can look at the failed authentication and the reason behind it. I don't have access to to an ACS server at the moment but I believe you go to "Monitoring & Report Viewer" then there is a tab in there where you can view failed AAA authentication attempts. Try finding that and seeing why your device is failing.
Suresh Babu
Is there any specific procedure to follow to configure this AAA like first authentication followed by authorizarion and administration
Regarda
Suresh
Sent from Cisco Technical Support Android App
