tagged frames
carl_townshend
Hi all, when we talk about a tagged frame, does this mean either 802.1p tagging or 802.1q tagging ? and will the ethertype be the same for both of these ?
5 Replies 5
hdt
Community Member
Hi Carl,
Please take a look at the following link:
http://en.wikipedia.org/wiki/IEEE_802.1Q
I think this will answer your question about the relation between 802.1p and 802.1q and the ethertype which is used.
regards,
Henk
bvsnarayana03
Level 10
Level 10
it is the 802.1q frame. Ethertype value & 802.1p are carried in the 802.1q frame.
Refer this link for further reference:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a008008019c.html
802.1p is carried in the user priority field of .1q tag frame.
pls rate if helped.
so is it possible to prioritize untagged frames then ?
no.
can anyone clarify this as im sure I have seen it where you can prioritize untagged frames
