Tagging DSCP values for Citrix traffic
Jason Flory
Hello Everyone
I need to enable QOS for citrix.  I am not too worried about QOS on the switches but would like to tag the traffic so that it gets priortized on our WAN.  One of the problems we are having is Citrix when using a netscaler uses dynamic ports.  I am trying to figure how to make the port assignment static.  If you know how to accomplish that task would be great.  Assuming that i get the ports statically assigned how would i tag this traffic?
Is it possible to just tag traffic and not do the rest of QOS requirments on switches?
If someone could give me an example of tagging traffic via port settings and example of source and destination IP would be great.
richard.gosling
Use PDLM which does away with port numbers and works on the application, but try nbar first as citrix is well known.
Have a look:http://www.cisco.com/en/US/docs/ios/12_2s/feature/guide/fsnbarad.html
Rich
Thanks Rich
I am reading the documentation now.  Is this an entire qos system or is it just a way to identify traffic?  Hopefully it recognizes the new Citrix clients which do multi-stream.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
NBAR is a feature to identify traffic.  Whether you need a PDLM or what it "knows" depends on the version of NBAR.
Tagging identified packets alone usually doesn't provide any special treatment.  (You can also give some traffic special treatment without tags.)
I'm not current on NBAR and/or Citrix, but NBAR used to allow you to examine Citrix's (earlier?) subtype (so you could treat Citrix screen interaction traffic different from Citrix printing, etc.)
