tcl script to identify unused ports
nikkitodd92
So I've been trying to find a way to run a TCL script on a large number of 3750 switches which will identify any unused ports and disable them, but I'm not entirely sure since the ports would always differ from switch to switch, the rest of the script as far as disabling them and putting them into an unused vlan is no problem, only the identifying which actual ports would need to run through and be shut confuses me. I would be pushing a job to multiple switches containg the script however for the life of me I am unable to come up with a way to identify the correct ports on a per switch basis by pushing only one script.
Ton V Engelen
Level 3
Level 3
Well
we struggled with some similar script or a while.
What we do is , a port is considered unused if both the input packet count and output packet count = 0 after an amount of time (days, weeks)
Example of unused port (we cleared all the counters on the switch 3 weeks ago)
GigabitEthernet1/0/6 is down, line protocol is down (notconnect)
    0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Hope it helps!
Oh wow, that is brilliant, but how would you pull that information. I assume you wrote it into an if statement, but how was that data pulled and differentiated from all others. Did you use a while loop to check all ports and then if the input and output packets were 0 then they were considered unused and placed into an unused vlan
yes, thats how it works here.
