TCP port not passing
dimkat2903
Greetings,
I am facing an issue. I have two windows servers where they can ping each other. Both of them are connected on the same switch (3850) and are assigned on the same VLAN. However, when I’m doing a test net connection from server 1 to server 2 on TCP port 135 then the TCP net connection fails. Firewall on both servers is disabled and the strange thing is that when I connect both servers back to back through Ethernet then the test net connection succeeds and TCP port 135 passes. Also, RPC service is enabled on both servers. I tried to configure an extended ACL to allow TCP from any to any and I applied it on the outbound direction to the interface that server 1 is connected so that to allow TCP 135 going to Server 2 but still same issue.
what could be the root cause please? Thank you
11 Replies 11
balaji.bandi
what is the version of  code running Cat 3850, and can you post the config of the switch (show run)
BB
dimkat2903
The firmware version is 16.12.05b
show run  ( will help to look what wrong)
if this layer 2 or Layer3, then run some debug ?
BB
here is the switch configuration. the switch is a L3.  can you suggest me some good debug commands for troubleshooting? is it something related to the global ACLs? As i said, i tried to set an extended ACL to allow TCP port 135 from Server 1 to Server 2 and i applied the ACL on the outbound direction to the switch port where Server 1 is currently connected but still same issue. Any thoughts please? Need to provide a solution asap so your support is highly appreciated!
I see ACL and permit many TCP port,
so first do traceroute from one server to other
and see hop it pass,
then check ACL under each hop (path between Server)
then do show ip access list, check hit count where it increase when you connect using TCP port.
Actually both servers are connected on the same switch so no hops are in between them.
Which ACL is affecting port 135 not to pass?
ip access-list extended AutoQos-4.0-wlan-Acl-Bulk-Data
ip access-list extended AutoQos-4.0-wlan-Acl-MultiEnhanced-Conf
ip access-list extended AutoQos-4.0-wlan-Acl-Scavanger
ip access-list extended AutoQos-4.0-wlan-Acl-Signaling
ip access-list extended AutoQos-4.0-wlan-Acl-Transactional-Data
these ACL apply where ? does it apply yo CoPP  of SW or apply to VLAN ? which VLAN these ACL apply to is it same as Server or not ?
All above ACLs are some default ones and were not created by me and are not applied to any switch port. The switch ports both servers are connected to, don’t have any ACLs applied.
do you config any CallManager, CallManager ca use TCP port 135
may this the issue because there is conflict between two service.
https://www.voipinfo.net/docs/cisco/43881-ccm-tcp-udp-ports.pdf
waiting your reply
You have provided the config, you are not given input where the Servers connected what port and what VLAN
1. on the Switch Server 1 connected to what port ?
2. on the Switch Server 2 connected to what port ?
3. what VLAN you think they are suppose to be ?
4. what is the Server 1 IP address
5. what is the Server 2 IP address?
6. can you post from Servers  ipconfig /all
7. Can you confirm From Server  1 to Server 2 that you can ping? and vice versa?
8. post-show IP arp from switch
BB
since both of your servers are in the same Vlan, no layer 3 ACLs would apply, in theory. Looking at your configuration, is there a specific reason why 'ip host-routing' is enabled ? I have never seen this on a straight layer 3 switch. Try to disable that, and simply enable 'ip routing' instead...
