Telnet
Hi.
I am having access a router by dial-up (central site) and having access by telnet a remote router. I obtain to enter with the configuration commands and to save, however the connection is blocked when I enter with any command show.
What it can be happening?
nambi_gct
Level 6
Level 6
what do you mean by connection blocked?do you see any error message?
Any output it's show me and the any command it's possible then i must CTRL+SHIFT+6+X
People?
Hi.
With local login (console or telnet by LAN) it's ok, but by WAN..... no (without show,?, debug, erros messages)
