Temperature shutdown with Cisco 3750
david foley
Quick question;
is it possible to have the Cisco Switch to shutdown if the temperature goes above recommend temperature
currently we have one Cisco Switch C3750x.
Thanks..
Mark Malone
Hi The only way you can shut down a switch is to disconnect it , most you could get it to do is reload there is no shutdown command available and on 3750s theres not even a power button only kettle lead connection you would plug out
ok thank you for your reply..
need to think of a way to get the power disconnected if the air conditioning Unit goes.
Probably you can try to create the EEM script to shut down the box when the specific threashold is reached/seen. Other than that there is no other way to achieve this.
Inayath
**please do not forget to rate the posts if usefull***
