08-27-2017 05:49 AM - edited 03-08-2019 11:50 AM
I am facing issue with WS-C4503-E switch. When i am trying to log in by telnet to switch then i am not getting links up and down messages although i enabled terminal monioter and logging synchronous etc but still out of result.
08-27-2017 05:55 AM - edited 08-27-2017 05:59 AM
My undestanding is you want to see logs, is that correct? Try to configure
logging on
logging buffered 5
logging trap 5
terminal monitor should display the logs on the screen.
08-27-2017 06:02 AM
08-27-2017 06:04 AM - edited 08-27-2017 06:08 AM
Try configuring under the interfaces:
interface range <interfaces range>
logging events link-status
If im not wrong, it is different config compared with other switches.
Hope it is useful
08-27-2017 06:12 AM
08-27-2017 06:17 AM - edited 08-27-2017 06:19 AM
Try configuring:
logging monitor 6
and
line vty 0 15
logging synchronous all
08-27-2017 06:23 AM
08-27-2017 06:51 AM - edited 08-27-2017 07:44 AM
Can you please share the output for this command:
show terminal | include Capa
you should see something like:
sho termi | i Capa
Capabilities: Receives Logging Output
Thank you in advance.
08-28-2017 04:38 AM
08-28-2017 04:41 AM
Apparently show terminal has not been enabled
#show terminal | include Capa
Capabilities: none
Please try again enabling it and verify again the output.
switch# terminal monitor
08-28-2017 10:30 PM
08-28-2017 11:20 PM
