Bookmark
Subscribe
1804
Test Netflow connectivity from Cisco Router or ASA
Mokhalil82
Level 4
Level 4
I have netflow configured on my router to send data to my internal server at 192.168.0.50 on UDP port 2055
I do have an asa in between and so I allowed icmp from the outside on the asa and I am able to ping the server using the source ip of 1.1.1.1.
How can i text connectivity to ping from source 1.1.1.1 port 2055 to dest 192.168.0.50 port 2055. ASA has the rules to allow the traffic
The config I have on the router is
ip flow-export source Loopback1
ip flow-export version 9
ip flow-export destination 192.168.0.50 2055
My router ports have ip flow ingress and egress configured
The issue started upon upgrading the router but using the same config.
Ive notice the rule on the asa to allow traffic from 1.1.1.1 to 192.168.0.50 is not any getting hits
joe19366
your best bet would be to capture traffic on the outside and inside of the ASA:
access-list 118 permit udp any any eq 2055
capture outside access-list 118 interface outside buffer 500000
capture inside access-list 118 interface inside buffer 500000
now
show capture outside
show capture inside
do you have netflow packets outside?
YES/NO?
do you have netflow packets inside?
you may not have netflow working if none outside
you probably dont have the access-list on ASA working properly if none inside ;)
are you sure the server is listening?
check.
Thanks for the info, I am not receiving any packets on the outside interface so looks like the config is not working, but I have used the exact same config from the old router I replaced so been through is a few times a to make sure it takes the config ok
I have checked the server and it is listening to the loopback interface
Hi Mokhalil82,
Have you resolved this issue?
