TestAclPermit Fail in WS-X6748-SFP
hello team!
i need help.
in my C6506-E installed module WS-X6748-SFP with WS-F6700-DFC3BXL
last time a see errors:
18:42:49: %DIAG-SP-6-TEST_RUNNING: Module 3: Running TestAclPermit{ID=23} ...
18:42:51: %DIAG-SP-3-TEST_FAIL: Module 3: TestAclPermit{ID=23} has failed. Error code = 0x1
23) TestAclPermit -------------------> F
Current bootup diagnostic level: minimal
        Module 3:
          Overall Diagnostic Result for Module 3 : MINOR ERROR
          Diagnostic level at card bootup: minimal
          Test results: (. = Pass, F = Fail, U = Untested)
            1) TestTransceiverIntegrity:
              Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16
              Port 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
                    .  .  .  .  U  .  .  .  .  .  .  .  .  .  .  .
              Port 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
                    .  .  .  .  .  .  .  .  .  U  .  .  U  U  .  .
            2) TestLoopback:
            3) TestScratchRegister -------------> .
            4) TestTxPathMonitoring ------------> .
            5) TestDontLearn -------------------> U
            6) TestConditionalLearn ------------> .
            7) TestNewLearn --------------------> U
            8) TestStaticEntry -----------------> U
            9) TestIndexLearn ------------------> U
           10) TestCapture ---------------------> U
           11) TestTrap ------------------------> U
           12) TestMacNotification -------------> .
           13) TestFibDevices ------------------> .
           14) testIPv4FibShortcut -------------> .
           15) TestIPv6FibShortcut -------------> .
           16) TestL3HealthMonitoring ----------> U
           17) TestNATFibShortcut --------------> .
           18) TestMPLSFibShortcut -------------> .
           19) TestL3Capture -------------------> U
           20) TestL3VlanMet -------------------> .
           21) TestIngressSpan -----------------> .
           22) TestEgressSpan ------------------> .
           24) TestAclDeny ---------------------> U
           25) TestQos -------------------------> .
           26) TestNetflowShortcut -------------> .
           27) TestLinecardMemory --------------> U
           28) TestEobcStressPing --------------> U
           29) TestFibTcamSSRAM ----------------> U
                  Error code ------------------> 1 (DIAG_FAILURE)
                  Total run count -------------> 1
                  Last test execution time ----> Dec 08 2011 14:16:18
                  First test failure time -----> Dec 08 2011 14:16:18
                  Last test failure time ------> Dec 08 2011 14:16:18
                  Last test pass time ---------> n/a
                  Total failure count ---------> 1
                  Consecutive failure count ---> 1
diagnostic start module 3 test 23
Module 3: Running test(s) 23 may disrupt normal system operation
Do you want to continue? [no]: yes
Dec  9 09:46:57 172.24.0.1 155: 18:42:49: %DIAG-SP-6-TEST_RUNNING: Module 3: Running TestAclPermit{ID=23} ...
Dec  9 09:46:59 172.24.0.1 156: 18:42:51: %DIAG-SP-3-TEST_FAIL: Module 3: TestAclPermit{ID=23} has failed. Error code = 0x1
many port in WS-X6748-SFP not work
GigabitEthernet3/23 is up, line protocol is up (connected)
but i cant find mac address on port
may be a problem because of "TestAclPermit -------------------> F" ?
thanks in advance!
Leo Laohoo
Try reseating the blade.  Otherwise, the blade needs to be RMA-ed.
smogra
Would advise to set the diagnostic level to complete and then re-seat. (right now, it is on minimal which is default.)
As mentioned above, most likely reseat should resolve the issue. But if the module fails, this will indicate a hardware failure.
--Sweta
Please rate useful posts.
thanks for answer,
re-seat not help
Thanks for the rating Dmitry.
Looks like your next move is to call Cisco TAC and give TAC the serial number of your 6500 chassis and get the blade replaced.
