testing port functionality
Ibbywannit
Hi everybody,
I've got a 6500 series router here with a 48 port module and was wondering if there was anyway that i can test that all the ports were functioning without having to physically plug them all in. Any help would be useful - it's running off of catOS.
JORGE RODRIGUEZ
Level 10
Level 10
Hi, you can simply issue " show test X " where X is module number.
you should get line card status as (. =PASS, F= Fail ) on each of the ports.
Rate any helpful posts
Jorge
Jorge Rodriguez
Thanks for that. How do i rate your post?
Hi, when reading the message look at lower end right corner for "Rate this post" , thank you in supporting the ratings.
Rgds
Jorge
Jorge Rodriguez
