TFTP: Error, insufficient flash installed to load image -C2811 router
TFTP: Error, insufficient flash installed to load image.
TFTP: Operation terminated.
rommon 7 > meminfo
Current Memory configuration is:
Dimm0: Size = 512 MB
-----Bank 0 256 MB
-----Bank 1 256 MB
Dimm1: Not Installed
Main memory size: 512 MB in 64 bit mode.
Memory config: ECC
Available main memory starts at 0xa0015000, size 524204KB
Smart Init is enabled.
NVRAM size: 240KB
rommon 8 >
kindly help anybody fix this issue. The image size is 64.7 MB, available memory 85 MB. but i cannot load my image.
7 Replies 7
Do you have already tried to format flash and squeeze flash before to load the new image?
Regards.
No. i did't try
Ok, can you test it and let us know what happens?
Regards.
And, make a backup of old image and current configuration before to format.
Regards.
Yes. I already taken backup. Looking for fix this issue.
Mark Elsen
- meminfo wll only display info concerning the memory size not the flash, use show flash instead.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
What is the IOS file you're trying to load? Maybe there's not enough flash/DRAM requirement?
