2960-XR Series Switches
pabene
I need to order 2960s, but a bit confused.  Silly question, but with the 2960XR-24PS, 2960XR-24TD, 2960XR-24TS.  What does PS, TD, and TS stand for?
And for 2960XR-48FPD, FPS, LPD, LPS?  FPD - full power distibution? LPD - Low Power Distribution?
2 Accepted Solutions
mkazam001
Level 3
Level 3
P - PoE
FP - Full PoE, all 48 ports
the end letter D or S is for uplinks -
D - 2 SFP+ ports
S - 4 SFP ports
it only comes with the IP Lite layer 3 license
regards, mk
please rate if helpful :)
these seem to be the options:
Cisco Catalyst 2960XR-48FPD-I      48 port full poe with 2 sfp+ ports
Cisco Catalyst 2960XR-48FPS-I       48 port full poe with 4 sfp ports
Cisco Catalyst 2960XR-24PD-I         24 port full poe with 2 sfp+ ports
Cisco Catalyst 2960XR-24PS-I        24 port full poe with 4 sfp ports
i think the sfp+ ports support both 1Gb & 10Gb links but please confirm before purchase
source:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/datasheet_c78-728232.html#Ordering-Information
regards, mk
7 Replies 7
mkazam001
Level 3
Level 3
P - PoE
D - 2 SFP+ ports
S - 4 SFP ports
regards, mk
So if I want to use 2960XR as my access layer switches, provide POE+ ports, and with option of 1 & 10 gig uplinks, which models would you recommend (a 24 port and a 48 port)?
source:
regards, mk
Thanks! Much appreciated.
Do the 2960XR's support 10 gig SFPs? It says they support SFP+, but can't find the SFP models for the 2960XR.
I think they have only either x4 SFP ports or x2 SFP+ ports - I think the SFP+ ports work with both 1Gb & 10Gb links
Regards, mk
fil in the switch model in the the tmg matrix and select 10G
Network Device Product ID Transceiver Product ID Data Rate Form Factor Reach Cable Type Media Connector Type Transceiver Type Case Temp DOM HW Capable Minimum DOM SW
WS-C2960XR-24TD-I SFP-10G-SR 10 Gbps SFP+ 300m (OM3) Duplex Fiber MMF LC Optic 0 to 70C Y IOS 15.0(2)EX1 IOS 15.0(2)EX1
SFP-10G-SR 10 Gbps SFP+ 400m (OM4) Duplex Fiber MMF LC Optic 0 to 70C Y IOS 15.0(2)EX1 IOS 15.0(2)EX1
