The switch is keeping going back to switch:
diallodjeri
Hi every one,
The console port is stuck at 115200 even after  changing it in ROMMON  mode to 9600 by set BAUD 9600 and unset command neither one seems to  help.
vijay.gaganam
Please check inside running-configuration, under "line con 0" section, If the baudrate is set to 115200.
Baudrate can be set for console by giving the command "speed 9600".
Vijay G
vijay.gaganam
Vijay G
Thank you very much,your are genius your suggestion fixed it for me
