The two standards supported by TIA/EIA: 568A and 568B
nalmeidanobre
In a switch model SG 100 - 24 i will use category 6 cables.
Which of the two standars supported by TIA/EIA 568A and 568B you advise.
Peter Paluch
Hi Nelson,
These two standards are equivalent - there are no functional differences between them. You may use whichever you want. If your existing network installation already uses one of these alternatives, remain with it to maintain a certain degree of consistency of your network design, but otherwise, you may choose any of them as they provide precisely the same transmission capabilities.
Best regards,
Peter
