04-23-2012 12:38 AM - edited 03-07-2019 06:16 AM
I have one 4506E switch working in Lan setup as a core switch with WS-X45-SUP6L-E running ipbase IOS 12.2(54)SG1. Each time after reload the switch we found that the clock is getting reset ( time is getting changed ) where as day, date & year is unchanged.
Pls. help to get it resolved. Thanks in advance.
Rgds
Pradip
04-23-2012 06:57 AM
I believe that is normal , it will not hold time across a reboot . For that you will need to get a definitive source for ntp and runn that across your network .
04-23-2012 03:31 PM
Everytime you reload a Cisco appliance, the clock will revert to the default time of "Mar 1". If you have NTP configured correctly, the time will be adjusted between 2 to 10 minutes after a reload.
