Total output drops Show same value on Multiple Interface of 6548GE module
adnan ahmad
Total output drops Show same value on Multiple Interface of 6548GE module in 6500 Switch.
GigabitEthernet2/17 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0019.56a4.6f38 (bia 0019.56a4.6f38)
Description: "PABX SIP-DXBDTCITINTIP02"
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output 00:00:39, output hang never
Last clearing of "show interface" counters 01:59:32
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 52811
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 261000 bits/sec, 268 packets/sec
5 minute output rate 240000 bits/sec, 262 packets/sec
1703970 packets input, 219687076 bytes, 0 no buffer
Received 40 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
1848838 packets output, 227878643 bytes, 0 underruns
GigabitEthernet2/18 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0019.56a4.6f39 (bia 0019.56a4.6f39)
Description: "PABX SIP-DXBDTCITINTIP03"
Clock mode is auto
5 minute input rate 221000 bits/sec, 233 packets/sec
5 minute output rate 217000 bits/sec, 240 packets/sec
1694335 packets input, 226373096 bytes, 0 no buffer
Received 205 broadcasts (0 multicasts)
1835526 packets output, 233149846 bytes, 0 underruns
GigabitEthernet2/19 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0019.56a4.6f3a (bia 0019.56a4.6f3a)
Description: ******dxbdhsq02***********
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Full-duplex, 1000Mb/s
Clock mode is auto
5 minute input rate 373000 bits/sec, 30 packets/sec
5 minute output rate 40000 bits/sec, 32 packets/sec
146193 packets input, 161433314 bytes, 0 no buffer
Received 7171 broadcasts (7164 multicasts)
219744 packets output, 39957030 bytes, 0 underruns
GigabitEthernet2/20 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0019.56a4.6f3b (bia 0019.56a4.6f3b)
Description: DXBDHSQ01-MGMT
input flow-control is off, output flow-control is off
Clock mode is auto
20 packets input, 2064 bytes, 0 no buffer
Received 4 broadcasts (0 multicasts)
10224 packets output, 805141 bytes, 0 underruns
GigabitEthernet2/21 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0019.56a4.6f3c (bia 0019.56a4.6f3c)
Description: " StaffNet Bluecoat Proxy DMZ Port"
Clock mode is auto
Last input never, output 00:00:34, output hang never
5 minute input rate 516000 bits/sec, 77 packets/sec
5 minute output rate 501000 bits/sec, 94 packets/sec
1588514 packets input, 1261196445 bytes, 0 no buffer
Received 254 broadcasts (0 multicasts)
1753754 packets output, 1219512391 bytes, 0 underruns
GigabitEthernet2/22 is down, line protocol is down (notconnect)
Hardware is C6k 1000Mb 802.3, address is 0019.56a4.6f3d (bia 0019.56a4.6f3d)
Description: "PABX SIP-DXBDTCITINTIP05"
Auto-duplex, Auto-speed
input flow-control is off, output flow-control is desired
Clock mode is auto
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 packets output, 0 bytes, 0 underruns
GigabitEthernet2/23 is down, line protocol is down (notconnect)
Hardware is C6k 1000Mb 802.3, address is 0019.56a4.6f3e (bia 0019.56a4.6f3e)
Clock mode is auto
GigabitEthernet2/24 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0019.56a4.6f3f (bia 0019.56a4.6f3f)
Description: ***dxbdlmmg01-voice***
Clock mode is auto
Last input never, output 00:00:31, output hang never
5 minute input rate 280000 bits/sec, 162 packets/sec
5 minute output rate 283000 bits/sec, 164 packets/sec
471441 packets input, 102388794 bytes, 0 no buffer
Received 1 broadcasts (0 multicasts)
480857 packets output, 103314707 bytes, 0 underruns
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Some 6500 line cards use the same ASIC for multiple ports, and when it drops packets, all the ports that it controls reflect the drop count.
