Total output drops
pchollatee
I found problem about "Total output drops" in interface. I aleady check bandwidth it use in 70Mbps and out 340Mbps. Capacity's port Gigabit.
Please advice me how to solve this problem.
Hardware detail
Cisco 7206VXR (NPE-G1)
Cisco IOS Software, 7200 Software (C7200-JS-M), Version 12.4(25), RELEASE SOFTWARE (fc2)
Cisco 7206VXR (NPE-G1) processor (revision C) with 229376K/32768K bytes of memory.
8 Replies 8
pchollatee
Addition information.
  Input queue: 0/75/122/1 (size/max/drops/flushes); Total output drops: 95929118
Can you show the whole inferface readout -also
sh int xx stats
sh int xx switching ( hidden command)
sh ip int xx
after that can you clear the counters on this interface-
clear counters xxx
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Hi, pdriver
     I send information to you, please advice me for solve this problem.
Thnak you.
As your request. After clear counter       error still occur.
Before clear counter
Gi 0/2
Router7200#
show interfaces gigabitEthernet         0/2 stats
GigabitEthernet0/2
           Switching path    Pkts In   Chars In   Pkts Out  Chars       Out
                Processor    7209523  923359228    5234663        440135296
              Route cache 21769959690 7886764852643 25881693493       20892284926960
                    Total 21777169213 7887688211871 25886928156       20892725062256
Router7200#
Router7200#
show interfaces gigabitEthernet         0/2 switching
GigabitEthernet0/2 "to SW-vio-foundry Port10 - first"
           Throttle count          0
                    Drops         RP       1140         SP                0
              SPD Flushes       Fast          1        SSE                0
              SPD Aggress       Fast          0
             SPD Priority     Inputs   17527981      Drops                0
     Protocol  IP
                  Process   50876322 4065761287  206773753       148377551856
             Cache misses       2787          -          -                -
                     Fast 110956388453 42309712030540 130932460306       103509586744379
                Auton/SSE          0          0          0                0
     Protocol  DEC MOP
                  Process          0          0      10965           844305
             Cache misses          0          -          -                -
                     Fast          0          0          0                0
                Auton/SSE          0          0          0                0
     Protocol  ARP
                  Process     848695   50921568    5521022        353345408
                     Fast          0          0        307            19648
                Auton/SSE          0          0          0                0
     Protocol  CDP
                  Process    1542342  547567427     110032         39280315
                     Fast          0          0          0                0
                Auton/SSE          0          0          0                0
     Protocol  Other
                  Process    2933192 1117028117     660024         39601440
                     Fast          0          0          0                0
                Auton/SSE          0          0          0                0
     NOTE: all counts are cumulative and reset only after a reload.
Router7200#
Gi 0/2
Router7200#
GigabitEthernet0/2
                Processor        729      89017        491            36991
              Route cache    4613321 1474215837    5754494       5168029769
                    Total    4614050 1474304854    5754985       5168066760
Router7200#
Router7200#
           Throttle count          0
                    Drops         RP       1140         SP                0
              SPD Aggress       Fast          0
             SPD Priority     Inputs   17528634      Drops                0
     Protocol  IP
                  Process   50877312 4065831708  206786739       148383515820
                     Fast 110964129298 42312080539620 130942214305       103518385025490
                Auton/SSE          0          0          0                0
     Protocol  DEC MOP
                  Process          0          0      10966           844382
                     Fast          0          0          0                0
                Auton/SSE          0          0          0                0
     Protocol  ARP
                  Process     848767   50925888    5521168        353354752
                     Fast          0          0        307            19648
                Auton/SSE          0          0          0                0
     Protocol  CDP
                  Process    1542400  547588105     110036         39281743
                     Fast          0          0          0                0
                Auton/SSE          0          0          0                0
     Protocol  Other
                  Process    2933299 1117068933     660047         39602820
                     Fast          0          0          0                0
                Auton/SSE          0          0          0                0
Router7200#
Router7200#
GigabitEthernet0/2 is up, line protocol is up
   Hardware is BCM1250 Internal MAC, address is 0050.0b36.b41a (bia       0050.0b36.b41a)
   Description: "to SW-vio-foundry Port10 - first"
   MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
      reliability 255/255, txload 74/255, rxload 20/255
   Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
   Keepalive set (10 sec)
   Full-duplex, 1000Mb/s, media type is RJ45
   output flow-control is XON, input flow-control is XON
   Last input 00:00:00, output 00:00:00, output hang never
   Last clearing of "show interface" counters 00:03:25
Input queue: 0/75/0/0         (size/max/drops/flushes); Total output drops: 28783
   Queueing strategy: fifo
   Output queue: 0/40 (size/max)
   5 minute input rate 79883000 bits/sec, 32407 packets/sec
   5 minute output rate 290321000 bits/sec, 40779 packets/sec
      6814390 packets input, 2182125529 bytes, 0 no buffer
      Received 244 broadcasts, 0 runts, 0 giants, 0 throttles
      0 watchdog, 7832 multicast, 0 pause input
      8496755 packets output, 7539414742 bytes, 0 underruns
      98 unknown protocol drops
      0 lost carrier, 0 no carrier, 0 pause output
Router7200#
Please provide the output of
show queueing interface gi0/2
Partha
Router7200#show queueing interface gigabitEthernet 0/2
Interface GigabitEthernet0/2 queueing strategy: none
Router7200#
paolo bevilacqua
What are the other interface in router, or complete config.
Also, wrong forum, post in "Small Business -". You can move your posting with the Actions panel on the right.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Gig port physically running at gig?
Your default egress queue, if 40, might be too small (leading to premature bust drop).  Try increasing egress queue's size, you might try 512.
