traceroute is not working but pinging
nilesh.dubey
I can ping an IP address but not traceroute. When I am trying to traceroute getting below response. Could anyone assist me to resolve it.
 1  *  *  *
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7  *  *  *
  8  *  *  *
  9  *  *  *
 10  *  *  *
 11  *  *  *
 12  *  *  *
Nilesh
6 Replies 6
Jon Marshall
Difficult to say without knowing what devices are between the source and destination IP.
Ping simply sends an ICMP packet to the destination IP and gets a response back.
Traceroute on the other hand sends ICMP packets with increasing TTLs so each L3 device along the path has to send a response to source IP.
So it could be acls, firewalls, router configurations etc. that are stopping the traceroute from working correctly.
Jon
Cisco is using UDP for traceroute actually.
So if the source device would be a Cisco switch, e.g., there could be an ACL or FW rule permitting ICMP echo (=Ping) but denying UDP (=traceroute) causing the symptoms?
Best regards,
Milan
Hi Jon,
There is no such access-list on router but I am not sure about the firewall, if it would be blocking.
Nilesh
Hello
Following on from Jons response- On the router try and either disable IP domain-lookup or use the numeric command
By default traceroute performs dns resolution
traceroute xxxxxx numeric
Res
Paul
Kind Regards
Paul
Hi Paul,
I tried that but it did not work.
Nilesh
Even if ICPM can be inspected and you can ping to the internet but when you do a trace to the same IP as you ping the firewall will block the returning traffic, I had the same problem until I allow icmp from any to the internal IPs as traffic hit the outside interface then everything worked.
