Tracing a Route going via VRF Routers
mahesh18
Level 6
Level 6
Hi Everyone,
Need to confirm my Findings.
I am tracing a Route from Switch at office 1  to switch at office 2.
Office 1 and 2 are connected by GRE tunnel going via Internet
Destination IP is 172.31.27.6
Here is path
Office 1
 Switch B----Next hop is 172.16.101.233   Switch C--
When i check the IP 172.16.101.233  on Switch C it is of VRF interface say corp.
So now i did
#sh ip route vrf corp 172.31.27.6
next hop is 10.100.142.2 tunnel11
Office 2
Switch D
sh run int tunnel 11
ip vrf forwarding corp
ip address 10.100.142.2
tunnel source Loopback 11
Need to confirm from Switch D  to find the next hop i should use the below command ????
MAhesh
2 Accepted Solutions
dimzaaaaa
Mahesh,
Yes that should work. Also another command to show the next hop would be
show ip cef vrf corp 172.31.27.6
Reza Sharifi
Hi Mahesh,
Yes, that is the correct command to see the route table for VRF corp.
Reza
dimzaaaaa
Mahesh,
Reza Sharifi
Hi Mahesh,
Reza
Many thanks Reza
MAhesh
