tracking solution?
davistw
Level 3
Level 3
I have a problem.
I have 2 security domains seperate by data guards. (See attached drawing)
The data guards pass ICMP ping traffic along with selected scrubbed traffic.
Each data guard injects a ospf route into the routing table that is weighted to send all traffic though the primary unless it is down.
Here is the problem.
If either router A or B fail (but not both) traffic will not pass because the opposite side still thinks it has a route though the primary dataguard.
Ie: if router A fails the traffic on the A side will be routed to to B side but the return traffic on the B side will still think it has a path though the primary because of the injected ospf route and it will go into a black hole. I would have to turn off both A and B in order for traffic to pass correctly though the B side
I am thinking I can do this via route tracking. Am I on the right "track"?
If so how would you set it up?
If not do you have a recommendation as to how I can do it?
Thanks in advance...
rais
Level 11
Level 11
You can use eBGP across the firewalls and iBGP at each site.
HTH.
Thanks rais....
The dataguards will not pass BGP traffic and I have no control over them. I am locked into the ospf routes that they inject. What I need is a way to detect that the routes are no longer valid and shut down the interface.
I think you can do it with EEM, I've tested and it's working fine.
Here is:
track 10 ip route 172.16.0.0 255.255.255.0 reachability
When route is DOWN:
event manager applet RouteDown
event track 10 state down maxrun 30
action 1 syslog priority warnings msg "Route 172.16.0.0/24 is down, shutting down Interface f0/0"
action 2 cli command "enable"
action 3 cli command "configure terminal"
action 4 cli command "Interface f0/0"
action 5 cli command "shutdown"
action 6 cli command "end"
When a route is UP:
event manager applet RouteUp
event track 10 state up
action 1 syslog priority warnings msg "Route 172.16.0.0/24 is up, enabling Interface f0/0"
action 5 cli command "no shutdown"
Hope it will help.
Best regards,
Abzal
