Issue with switch port voice vlan config
shanilkumar2003
Dear All,
I have configured one switch port on WS-C3548-XL for data and voice vlan but voice vlan is not coming up and ipphone connected is not getting ip.
below is the config,
interface  fastethernet 0/5
swicth mode access
switchport acces vlan 88
switchport voice vlan 140
spanning-tree portfast
the vlan is present in the switch and voice vlan is working perfectly in other switches, appreciate any help to resolve the issue.
Thanks in Advance,
Shanil
2 Accepted Solutions
Reza Sharifi
Can you try below config and test again?
switchport mode trunk
mahmoodmkl
Level 7
Level 7
switcport trunk native vlan 88
6 Replies 6
If this vlan is working and  not working only on this switch alone then you can check the following thigs.
1.check the free ip's space in the DHCP for this subnet.
2. check the trunk config and allowed vlan.
3. Also show spanning tree for this vlan.
sh run interface trunk
show interface trunk
show vlan
show spanning tree vlan fa0/5
thanks
V.S.Suresh .
Reza Sharifi
joelgooding
Question: is the ip phone a cisco ip phone? If it isn't then set the port to a trunk port.
Sent from Cisco Technical Support Android App
Joel _______________________________ Please rate helpful posts and answered questions!
I would also verify what the OP didnt say, is the phone getting power?  Layer 1, layer 2, layer 3.....
mahmoodmkl
Level 7
Level 7
Thank you all..
Thank you reza ..the below config solved the issue..
Reagrds
Shanil
